Old 09-01-2009   #1
Spanky1965
Cool bad stutter at 2000 rpm, only power key on
hello all, newbe here, I am sure this has been covered but this car is driving me crazy.
Runs perfect under normal power, but turn on the power key and idle goes up, and at exactly 2000 rpm's at part or full throtle it sounds like it stutters, bad, clears up at 5500 and pulls hard to 7500.
I have changed the fuel filter and pumps. new plugs. From what I have read in other posts it sounds like bad injectors, but it realy feels like a carb with the choke sticking. I was wondering if the 2nd ports are not opening. I am in Springfield Missouri and need help
Spanky1965 is offline   Reply With Quote
Old 09-01-2009   #2
Spanky1965
Default Re: bad stutter at 2000 rpm, only power key on
just wanted to add the car sat for 3 years before i got it, it has 30,000 miles, and had the vacum line that runs to the comp on the drivers side disconected.
Old 09-01-2009   #3
tccrab
tccrab's Avatar
Try this test:
Turn the Engine Power Key to off.
Run it hard, all the way up to 7000.
Turn the Engine Power Key to On.
Do the same thing.
You should notice a significant difference in power between the settings.
If there's only a slight difference or no difference at all, your secondaries system is suspect. Injectors, secondary actuators, secondary vacuum components will all cause symptoms like these. The fun part is figuring out which.
Here's everything you should ever need to know about your secondary port vacuum system:
http://www.corvetteactioncenter.com/...diagnosis.html
Good luck!
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 09-01-2009   #4
Spanky1965
thanks Tom, the funny thing is there IS a big diff, not even close. also the vac pump runs for 3 sec and does not cycle on and off so i am assuming no vac leaks
Old 09-01-2009   #5
tccrab
tccrab's Avatar
Ok, so no huge vacuum leaks. That's good.
Narrows it down a tick.
Your secondary actuators could be sticking and then opening later than they should. That would cause a mid rpm bog as the fuel mixture goes rich and then once they're open, the power comes back as the mixture leans out.
It could be fuel injectors, if you've got secondary fuel injectors that aren't flowing like they should, it could cause a bog.
Coils can cause stumbling problems, check out this 3 year long horror story:
http://www.zr1netregistry.com/forum/...ead.php?t=1777
Doesn't sound like your problem though, my first guess would be fuel injectors, secondary actuators next.
TomC
"Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 09-01-2009   #6
Spanky1965
I agree, but can you test the secondary actuators without removing the plenum?
Old 09-01-2009   #7
Is the 2ndry MAP sensor under the ECM connected?
Old 09-01-2009   #8
Spanky1965
yes it was diconected when I got it, but my friend did not drive it like you or I would, so not sure he even noticed. I have conected it
Old 09-01-2009   #9
I'm not sure that this would work. The secondary actuators are twined and the line off of the left bank actuator is T-'ed to go to the 2* MAP sensor(under the ECM bracket). Maybe if you pull the line at the MAP and apply vacuum to it you might be able to watch the actuators' arms thru the gaps in the plenum runners.
I'm not sure if that will work.
Old 09-01-2009   #10
Kb7tif
I bet your secondary throttle plates are not opening up or vacuum/injector problem. This stuff is generally easy to fix if you understand the system.
Here is a start.http://www.corvetteactioncenter.com/...diagnosis.html
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
