Old 07-19-2009   #21
Default Clutch install sucks
Well the tear down was easy. Install, PITA so far.....I borrowed a trans jack, the jack has a V in it and others have used it successfully, so this is an operator error issue.
I found out that when I tried to move the trans to position it, it would slip in the V in the trans jack, ultimately flipping completely in its side. I rightsided it 2X before going out and buying a trans jack adapter, only issue was that to get it under it had to go in on its side(trans). So I ended up putting the trans on the floor, sliding it under the car on a board. putting the tail end of the trans on the trans jack, then lifting the front with one arm and sliding the jack with the trans adapter under the front with the other.
The trans is now in postion....still need to stab the pilot bearing.
PS: 16"s of clearance is definately not enough! Wife also is out hounding me also....when is this going to be done.
Old 07-20-2009   #22
Kb7tif
Default Re: Clutch install sucks
Work until frustrated then quit, next day will have a new perspective.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 07-20-2009   #23
rhipsher
rhipsher's Avatar
Lee did you make some guide studs to screw into the bell housing yet? If not I would suggest you do it. They will help you line up and guide the trany in.
Old 07-21-2009   #24
Kb7tif
This will make it much better lining that trans up! Make sure they all protrude exactly the same. Push the trans up against the bell housing with one hand while turning the rear trans shaft slightly with the other, you will feel it catch.
i used my impact wrench to drive the bolts on the brace much faster.
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 08-25-2009   #25
tf95ZR1
tf95ZR1's Avatar
Default Re: McLeod Flywheels-aluminum
Anybody with personal knowledge or experience compare the McLeod vrs. Fidanza? This was never answered except
that there is a $$ difference.
Thanks
Old 08-25-2009   #26
No noise from the Mcleod, per my bathroom scale its about 16.5 pounds.
Old 08-25-2009   #27
Originally Posted by Aurora40 View Post
What is different about it that sets it apart from the Fidanza?
The Fidanza is about 3.5 lbs lighter.
Old 08-25-2009   #28
Keep in mind I weighed it on a bathroom scale, which may not be super accurate one way or another, website did not give the wieght.
Old 08-26-2009   #29
cward
cward's Avatar
Trying to remember is hard for an old man. However I think my flywheel on #364 was McLeod. Seems like it was 13 lb but could have been heavier. It was put in about 2000 and stayed in the car to the end. Tried several different clutch disks but mainly used stock disks and pressure plate. Got them from Carolina Clutch. That setup with 4.10 gears worked well for me. It held using ET Street slicks and coming off the line very hard using spray. It was fairly noisy as usual with a single mass but with my exhaust, that was a minor detail. That flywheel is one of the things I kept. That setup with slicks and spray got me in the 1.5 - 1.6 60'. Also worked just fine on the street and ORR. Can't even begin to remember how much I paid for it.
Curtis
Curtis Ward
91 ZR-1 #364 RIP
cward is offline   Reply With Quote
Old 08-26-2009   #30
There is a guy over on CF with an LT4 that had a hardon for a DM flywheel,found one and paid $1200 for it.It seems to me that the ZR-1 crowd would be just as happy with something other than the DM flywheel,does that seem about right?On a side note,$1200 for a flywheel?
