08-01-2009 | #1 |
Help Identify a fuse.
I found a blown 15 amp fuse and was hoping someone knew what it was for. Its located in the hidden fuse block under the dash on the passenger side. There are two rows to this fuse block - one in the front and one farther behind. The one I'm referring to is the row in the back second fuse in from the left. I stuck a mirror under there (one of my wife's compacts) and tried to make out what it says - something like "a common"..........I'm not really sure. I replaced it (whatever it is) but dont know what I just fixed.
Thanks |
08-02-2009 | #2 | |
Re: Help Identify a fuse.
According to page 262 of my 1991 Owners manual you replaced the Accessory Plug, Cigar Lighter. Which is a grouping of three wires normally hidden under the console shift plate. It was there in order for you to be able to hard wire a Cell phone back in the day or another power point. This started for the first year in 91 as the MY 90 does not have this option. It is under the back side edge rear of the console shift plate next to the seat control switches and the FX-3 select switch. Sal if you dont have an owners manual for your glovebox you need to get one on Ebay, critical info is in there. GC http://cgi.ebay.com/ebaymotors/1991-...sQ5fLiterature
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 08-02-2009 at 03:42 AM. |
08-02-2009 | #3 | |
Thanks for the info. I do have the owners manual, it just didn't occur to me it would have that info. On a side note, for some that don't know, fuses for these cars often handle multiple accessories. For instance I found that when you pull the courtesy light fuse you will also lose your stereo and I believe your a/c control as well.............and to think GM went BK, unbelievable isn't it? |
08-02-2009 | #4 | |
Id have to disagree Sal, if GM had run every functon to an independent fuse the size of the fuse block would probably tripple. Nature of the beast
