04-28-2009 | #1 |
basic questions
1991 ZR1 w 75k miles.
I have the start of a very small oil drip. I was using mobil 1 (10quarts). Should I change I like the bosch filter what are the torque specs for the oil drain plug what are the torque specs for lug nuts what is recommended for coolant (I think I remember 50% distilled and something else, I'm about the pull the rad and clean it and just want to make sure im putting the right coolant in it for Florida weather) thanks in advance, you guys on this forum have been great. Without you Id be much poorer and have a poorly running car. |
04-28-2009 | #2 | ||||
Re: basic questions
Fix it
04-28-2009 | #3 |
Re: basic questions
thanks Jeff,
Should I mix it 50/50 with the distilled??? How many quarts of oil?? How much coolant or coolant H2O mix?? |
04-28-2009 | #4 |
Re: basic questions
04-29-2009 | #5 |
Re: basic questions
Jeff's right, water does a much better job of dissipating heat than coolant. In summer time i tell my customers to go 70/30-80/20 water/coolant ratio. But not at the race track...water only!
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
04-29-2009 | #6 |
Re: basic questions
04-29-2009 | #7 | |
Re: basic questions
Hi guys.... Another of my thousand questions: Which is the best complete manual for Zr-1?And where i can buy it? I'll like to buy a technical manual where i can find all the spec for lt5, with the right torque for all nuts and screw (the most important)?? Thank you so much |
04-29-2009 | #8 | |
Re: basic questions
04-29-2009 | #9 |
Re: basic questions
04-29-2009 | #10 | |
Re: basic questions
The set (5 sets of documents and supplements) runs $105 plus about $16 S&H. Coolant.... Texaco 'green stuff' also meets the 1825M spec Jeff noted
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
