01-25-2009 | #1 |
Lamp size 74, buy it and throw it in the console
Well mines in my glove box but not every ZR-1 has a glove box so throw it in your armrests for my MY 94-95 friends. Most folks don’t know that im a daily driver and I drive my Z about 60 Miles daily from work to home. My ZR-1 gets a lot more wear and tear than most ZR-1 owners so I notice when things don’t work.
Case in point. I highly recommend every ZR-1 owner or C4 owner for that matter should stock up on type 74 mini lamps. Why? Well you will be surprised how many places in the car those little buggers fit and it’s not a normal size that most people have on hand in the garage. Sometimes they are a bugger to find as well as some stores have maybe one or two blub cards on hand depending on the auto parts store. These little lights are behind 90% of the orange night glow lights that barely illuminate when you drive your car with the parking lights or headlights on. Even the orange light under your rear view mirror is a type 74 bulb. I have been through 3 of these blubs so far this year which I am sure is a mixture of the age of the car (I drive a 91) and the amount of use per week I get out of it which adds age to all the components. Just something to think about you swing into the auto parts store next time for a bottle of oil. May save you a trip back some day I’ve learned a few tricks along the way on these bulbs. I just wanted to share Under the mirror the bulb light can be accessed by using a small jeweler’s screwdriver next to the diagonal amber lens that fits within a small black plastic square. Don’t poke the screwdriver into the diagonal slot or you break the lens. Gently pry out the black plastic square housing to reveal the bulb Under the door handle light in front of the clear fuse like light bulb is a double grey wire. It is retained into the door handle light housing with a small cotter pin. Push the pin through with a jeweler screwdriver to release the blub and the wire from the door light handle housing. The blubs maybe difficult to remove but gently pry them out with a pair of needle nose pliers. Have fun GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-25-2009 at 03:29 AM. |
