Old 09-28-2008   #11
Default Re: Dumb*** move of the day
Lee,
You called with a dead motor. Then my other friend Bob showed up with his 93. While gassing up at the BP, he noticed a screw in his rear driver's side drag radial. I should have figured the stars were misaligned. The track sucked. Huge crowd of fuelers, sport bikes, Super Comp etc. Little time for test and tune. On my second pass, I hit second gear and the car just sat there revving at 7k. Then it began to pivot towards the outside of the track. Let off and got it back going straight but damage was done. The guy in the LS-7 C5 Z had a problem at the same time. Turns out his clutch was goin. 2 bad passes and I got outta there. Sorry it cost you $100. Maybe US 41 will be a different story on the 11th.
Old 09-29-2008   #12
blackjack
youd be surprised the number of women running out of gas on their motorcycle...i have a 2 gallon always ready at the shop
bj
blackjack is offline   Reply With Quote
Old 09-29-2008   #13
blackjack
....and guys too !!
Old 09-29-2008   #14
tf95ZR1
tf95ZR1's Avatar
I agree, you are a brave and confident man to admit what happened.
We can all laugh together. Like the time I called Jeff Flint in a panic
when my newly assembled motor wouldn't start. Forgot to depress the
clutch.......
Old 09-29-2008   #15
It really just pi**** me off that had the guage been working I could have freakin walked across the road to get gas and then on to the track. Checking the tank never crossed my mind as the guage read over 1/4 tank, and I depressed the valve on the fuel rail and there was pressure and gas........which I know means there is pressure but does not define the quantity in the tank.
92 ZR1
#234
Old 09-29-2008   #16
clutch.......
THIS IS VERY TRUE!!
And it gave us all a chance to rub it in a little!!
Kudo's to you LG
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 09-29-2008   #17
karterdon
karterdon's Avatar
l
Lee - Inside every dark cloud is a silver linning - It could have been worse - You may have suffered some mis-fortune at the track - Like a clutch issue, Broken drive / axle shaft or wose yet a major engine issue. Maybe the ZR-1 God was looking out after you.. But you might want to go visit - "thepartsladi.com" and consider a new fuel pump / Level assy. - 275.00 while they last !!!
karterdon is offline   Reply With Quote
Old 09-29-2008   #18
thepartsladi.com
no good now! Linky no worky
Old 09-30-2008   #19
flyin ryan
flyin ryan's Avatar
clutch.......
ouch...that smarts Ted.
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
