05-26-2008 | #1 |
Q: Power steering pumps?
I may need to replace mine - bearings may be bad. I checked with a few sources and all I find are pumps that have separate resovoirs for the 90 ZR-1. I assume the pump and resevoir are separate, but I'm not sure. Before I take mine off (or more to the point, order one) AND invite all the headaches of purging issues, can anyone tell me if our (90) pumps have a separate resovoir or is there a special pump for our Zs??? I'd hate to get the wrong one.
P. |
05-26-2008 | #2 | |
Re: Q: Power steering pumps?
05-27-2008 | #3 |
Hey Paul, our 90 pumps, and all the rest I think, have a remote resevior.
I'm 99% positive on that info. Tom
05-27-2008 | #4 |
Correct. If I had looked at the FSM before I posted this trivia, I'd have known. But, thanks for the response(s), anywho.
P. |
05-27-2008 | #5 |
Have you figured out if this is a common part?
05-27-2008 | #6 | |
05-28-2008 | #7 |
Mine is a MY95, but the reservoir is separate and "wraps around" the pump.
The pump was surprisingly easy to find at my local parts store (Autozone?) and not too expensive. I vaguely remember needing a pulley puller. I also highly recommend replacing the rubber high pressure hose with a braided SS hose. If you were running dry, someone said you might have metal shavings in the system and should replace the rack also. I didn't and all seems fine. Good luck, Ted PS I believe our pump is different than a C4 pump and mounted differently. Last edited by tf95ZR1; 05-28-2008 at 02:41 AM. |
05-28-2008 | #8 | |
Good to know!
P. |
