Old 04-03-2008   #21
Jeffvette
Default Re: High HCs on Emissions
Originally Posted by XfireZ51
Arctic,
The trace shows that HC is moving up during decel. Maybe you need to cutoff fuel faster on decel. Could be a calibration change.
And that is masking an issue. Not recomended. This car in good running condition should pass easily.
Old 04-03-2008   #22
Arctic91
Arctic91's Avatar
Hey Jeff... thanks for asking. Here's a quick update:
A couple weeks back, I made the mistake of bringing it into a local shop that has a good rep for diagnosing emissions problems. A week and $300 later, they were scratching their heads and claimed "internal mechanical problem" as the root cause. Still not throwing codes and everything seems normal. No mods to the car- bone stock - so it shouldn't be this difficult. Lesson learned: stick to those who own a Z to diagnose a Z.
Nitrous Junkie took a look at it for me and ran a leak down test with no issues noted, so I concluded that the other shop was grasping at straws (pretty hard to disprove that diagnosis). Next, I started changing the easy things. New fuel filter and O2s haven't made much of a difference - still running rich, partial throttle "stumbling" and what seems like an intermittent miss at idle. I have new injectors (accel) and ignition wires (MSD) ready to go, but won't be able to get to that until the 12th (with a little help/teaching on the finer points of under-plenum plumbing from Nitrous Junkie and Zr1 Destroyer).
I really hope that the new injectors will do the trick and that the cats haven't been wrecked from it running rich. I'm not sure how long the problem existed before I bought the car... could have had 4 or 40k miles worth of unburned crap filtering through there. I'm thinking that new cats would be the next move if the injectors don't solve the problem. Does that sound logical?
Scott
'95 Callaway SNAT 450 Aerobody Coupe - Black/Black
'92 Callaway SNAT 400 Convertible - Polo Green/Beige
'91 ZR-1 #1231 - Arctic White/Saddle (SOLD)
'90 ZR-1 #2547 - Turquoise Metallic/Black
'89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black
'85 Corvette 454 Coupe - White/Red
Arctic91 is offline   Reply With Quote
Old 04-03-2008   #23
guinnessdood
guinnessdood's Avatar
Scott...if you don't get it to pass with the new injectors I'll be really surprised...but if it doesn't...borrow Ry's "emission exhaust" that is propped up to his fence next to his garage. After you pass...remove his exhaust and install a Corsa...or a B&B (with some aftermarket cats) if you prefer and a set of headers (I think Rod has a used set layin around)....now you'll sound like a ZR-1!!! :-)
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 04-03-2008   #24
cope05
headers laying around..........PM me please with the info if that is the case.
cope05 is offline   Reply With Quote
Old 04-03-2008   #25
Arctic91
Arctic91's Avatar
Uly,
I've had the same thought a couple of times... wish me luck once the injectors are in.
