Old 07-26-2024   #1
scorp508
Question What thread is the fuel rail where the Schrader valve connects?
I'd like to move my Scrader valve a bit by turning it up 90* to retain the ability to relieve pressure and take a mechanical reading, as well as have a second port for a permanent electric fuel pressure sensor. The stock location is pretty tight against the IAC motor. Anyone know the thread pitch off-hand at the end of the fuel rail? I've seen -4AN and -6AN mentioned. Thank you.
scorp508 is online now   Reply With Quote
Old 07-27-2024   #2
Default Re: What thread is the fuel rail where the Schrader valve connects?
I don't think the schrader valve is removeable from the rail, it is permenantly affixed to the end of the rail. I have seen valves tig welded in the end for special purposes, such as you are planning.
Old 07-28-2024   #3
1991 Corvette ZR-1
Nitrous Outlet has a schrader adapter block available which would allow you to use the existing shader to thread onto. From there, you can install a new schrader valve, as well as a sensor for fuel psi monitoring. Originally developed for LT1 and LT4 engines I believe, but it can work on LT5s as well.You will need a core removal tool to remove valve inside the shader.
https://nitrousoutlet.com/products/n...SABEgLECvD_BwE
Edit: it should be a 4AN fitting. A 9/16 wrench should fit the fitting that threads onto the schrader.
Old 07-29-2024   #4
scorp508
Thanks guys, this is great info.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
