Old 05-12-2024   #1
efnfast
Default High idle
Sometimes my idle gets stuck north of 2,000 rpm. It doesn't seem to be throttle related, as in the cable or plates.
The only way to get it to come back down is pull over, come to a complete stop and wait a bit. Less than a minute.
Thoughts?
Old 05-13-2024   #2
Young1
Young1's Avatar
Default Re: High idle
Buy throttle body cleaner spray. Remove accordion. Spray clean all well. Especially the little plate. Remove aluminum cover over cable. Spray all the mechanism with spray. First idea is grime because you have a higher mileage car.
Steve Young
Second Owner
SOLD
SOLD
Old 05-13-2024   #3
efnfast
I'll try that Steve, but it doesn't seem to be plate or cable related. If it was, I should be able to "tap" it down, or I could push in the clutch at speed and let it come down. It won't. The only way to get it to come down is bring the car to 0 mph. It feels like it's tune related.
Old 05-14-2024   #4
tccrab
tccrab's Avatar
My '90 does something similar, but not as extreme.
Approaching a stop the idle is around 1400rpm, once stopped for a few seconds the idle drops to 800ish.
Ive always believed it was smog related and allowing the cats to stay hot on deceleration.
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 05-14-2024   #5
I had that issue some years ago. My TB is bored to 63mm. I ended up buying Marc?s ?helper spring?. After all these years the return spring loses some of its closing power. Haven?t had that issue since.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-14-2024   #6
efnfast
It doesn't feel mechanical. I can coast down the highway with the clutch in for miles and the idle will never come down. Not until I come to a complete stop will it self correct.
Old 05-14-2024   #7
Young1
Young1's Avatar
Quote from service manual
Incorrect minimum idle speed may be caused by foreign material accumulation in the throttle, bore caulking, on the throttle valve, or on the throttle shaft.
Also a little research indicates to remove the IAC idle air control on the passenger side of the Plenum. It?s round with two small flanges, remove it, clean it and clean the passages in the plenum.
Hope this helps for your high miler
Steve Young
Second Owner
SOLD
SOLD
Old 05-15-2024   #8
Mystic ZR-1
Mystic ZR-1's Avatar
I do that every couple of driving seasons, never had an idling problem.
You'd be suprised how much stuff is on it.
Old 06-09-2024   #9
efnfast
This is what my mechanic suggested and it sounds perfect. I'll get some throttle body cleaner before I take it apart.
Old 06-23-2024   #10
efnfast
Thanks Yun, I think you fixed it, no problems coming home. I'll get some cleaner and pull the IAC again and give it another shot.
