6 Days Ago | #21 |
Re: 1992 Upper Radiator Shroud Removal
Mystic ZR-1,
Thanks. Have used DeWitts several times in other Corvettes with good results. Question - has anyone used Marc's 170 degree thermostat? Would like to know if it helps when driving in high Texas summer heat stop'n'go traffic. Gary .... |
5 Days Ago | #22 |
OK guys, have all the bolts/nuts/screws out of the radiator shroud.
Driver's side up in the air approx 25 degrees. Pass side - unable to get passed the A/C lines, especially the lowest one. What's the trick to get the right side of the upper shroud out? Thanks, Gary .... |
5 Days Ago | #23 |
For me, it was a lot of trial & error, just hoping I wouldn't break anything. However you get it out, remember because it goes back the same way.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
4 Days Ago | #24 |
Subfixer,
Got'er out. Had to trim a tad bit more off of the pass side shroud mount and slightly use a prybar to get around the lower A/C hose. Radiator had some debris on it, but not bad. Appreciate your help and guidance. Thanks, Gary .... |
