6 Days Ago | #1 |
1992 Upper Radiator Shroud Removal
Help with upper radiator shroud remova;
- all fasteners removed - see attached screenshot Upper radiator shroud seems stuck to radiator. When I pry up on driver's side flange with some force, the shroud will raise 1/2 inch, but that's it. Did I miss some fasteners or ? Thanks in advance, Gary .... |
6 Days Ago | #2 |
Re: 1992 Upper Radiator Shroud Removal
Did you get the 3 on each side? 8mm head.
Also 2 on each side down by the frame rails. Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
6 Days Ago | #3 |
Subfixer,
Thanks for info. Just found the drawing that shows 3 on each side - see screenshot. Question - how in the heck do you get to those? Do you have to take the air pump off on the driver's side? Thanks, Gary .... |
6 Days Ago | #4 |
Yes. I had to remove the air pump to get to mine
5 Days Ago | #5 |
Subfixer,
Any secret steps/processes to removing the air pump? Don't have a lift, so I'll have to jack it up and use a jack stand. Thanks, Gary .... |
5 Days Ago | #6 |
If I remember correctly, it was just a couple of bolts. I disconnected everything from the top. Remove the hoses from the pump. It doesn't need to move far.
5 Days Ago | #7 |
Subfixer,
Thanks. Will give it a go. Gary .... |
4 Days Ago | #8 |
Subfixer,
How did you go about getting the 3 8mm screws/bolts out on the passenger side? Did you use a flexible long extension or ? Those screws/bolts are very akward for this old man to get to. Your help is much appreciated. Thanks, Gary .... |
4 Days Ago | #9 |
Yes. Very hard to get them. I used a small 8mm wrench for the ones I couldn't get with a 1/4 " drive ratchet, extension and universal joint.
4 Days Ago | #10 |
Once all the bolts are out, the next challenge will be getting it out from under the AC and oil cooler lines.
