Old 08-07-2023   #1
EvanZR1
EvanZR1's Avatar
Default DRM coilover height for best ride
Adjusting the ride height on my new to me Admiral Blue ZR-1 with DRM coilovers and FX3 shocks. Any suggestions for best height for good ride comfort? Scott had it super low, which looked great, but had some pretty significant bounce on bumps. It was not even 1 finger between the front tires & fender, and barely over 1 finger between the rear tires & fender. I've brought the front up to 2 fingers between the fender and tire, and the rear is between 2-3 (just over 2 on the left, full 3 on the right). The ride is better, but still has some noticeable bounce on bumps, I'm thinking I probably need to go a little higher in front, call it 2.5 fingers, and maybe 3.5 finger widths on the rear. Thoughts or suggestions?
Ride height when I bought it:
After first adjustment:
Evan
2024 Z06
SOLD - 1991 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
Old 08-08-2023   #2
HAWAIIZR-1's Avatar
Default Re: DRM coilover height for best ride
I am watching this post as I am planning to finally get mine done after all these years. Same setup, but not sure what spring rates you are running? Mine are 425 front and 250 rear as recommended by Randy for my use. I cannot go too low and want a decent ride. I do not have a stock front bumper and have my custom carbon fiber ARP front splitter to protect.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-08-2023   #3
EvanZR1
EvanZR1's Avatar
Not sure on the spring rate, they seem fairly soft and if I remember correctly 425/250 was the common spring rate for DRMs. The problem with going too low is the car becomes really "bouncy" on bumps. I went a little too low on the previous steel blue car, and just lived with it. Scott had this one all the way down, and it was noticeably worse for the bounce. Options are either go with a stiffer spring or raise it back up. Going with a stiffer spring and running low should really be matched by changing shocks to something designed for the shorter travel. This isn't going to be a track car (at least not often), so I'd rather keep the FX3 and raise it back up to a height where it's comfortable. It may take me a few weeks, but I'll keep updating here so you can see my results.
Evan
2024 Z06
Old 08-08-2023   #4
HAWAIIZR-1's Avatar
Thanks Evan! It sounds like a pain in the arse to dial it in a get it right where one wants it with a lot of patience. Hopefully someone else with the same setup with chime in. I really want to install my set.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 08-09-2023   #5
IIRC, mine are 425/300. Also, using 18/19? wheels helps give the car a ?raked? look w/o the necessity of lowering too far.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-10-2023   #6
dredgeguy
dredgeguy's Avatar
Sitting perfect!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-10-2023   #7
JimZRyd
JimZRyd's Avatar
My 94 is on QA1's. The rears are 425, can't remember the fronts. I've got about 1.5 fingers front and back. She's stiff but not bad. A little bounce over rough spots. Very comfortable over all.
File Type: jpg E9791F05-4097-4640-A7E1-95B2F7757FE7.jpg (224.6 KB, 30 views)
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 08-11-2023   #8
98indypacer
I originally had 275lb springs on the rear per Randy's recommendation. But I have the car cranked pretty low so I was on the bump stops too often. I changed to 350lb springs and it rides much better.
98indypacer is offline   Reply With Quote
Old 08-17-2023   #9
Prez1967
I'll get new measurements tomorrow but when I talked to different people with lowered ZR1/Callaways about ride height, I was told:
Front: 25 3/4- 26"
Rear: 26 5/16-27"
Im pretty sure Im lower in both regards but im also running Ridetech coilovers. Front geometry should be the same (Ridetech shocks are Fox units made for this kit) and rear geometry is mounted differently from what I understand.
I've got no issues with bump or rebound and could likely go lower without detriment in ride quality but wanted to be able to clear a speed bump in my neighborhood.
1994 #353 "Bluey"
Prez1967 is offline   Reply With Quote
Old 08-17-2023   #10
EvanZR1
EvanZR1's Avatar
Adjusted the rears up some more, I'm now right at 5" to the frame rail in front and right at 5.25-5.5" at the rear. The ride is better but still has some bounce, but nothing near as bad as it was before. I may just have to do stiffer rear springs as I really don't want to go any higher. Of course, I could just pull the whole setup and replace with VanSteel's DA4 max lowering setup.
Rear coilover after adjusting:
Evan
2024 Z06
