08-29-2022 | #1 |
Dual Mass Flywheel interchangeability
I've been asked whether a 1989 L98 dual mass flywheel is interchangeable with a ZR-1 flywheel. I do not know the answer, although I can see that the GM part numbers are different - 10174481 for the LT5 and 10174482 for the L98. Can anyone help to broaden my knowledge on this subject please!?
Richard 1990, numbers 1821 and 2391 1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's 2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch. |
08-29-2022 | #2 | |
Re: Dual Mass Flywheel interchangeability
08-29-2022 | #3 |
L98, LT1 & LT4 flywheels all have 6 bolts to crankshaft, LT5 has 8. As Yun said, not interchangable.
08-29-2022 | #4 |
