07-24-2022 | #1 |
Cruise control shutting off when using blinker
So the cruise control works but when i turn the blinker on the cruise control shuts off. I recently had no brake lights working and replaced the brake light switch. I also had a keyless entry installed: simple lock and unlock from Avital. Anyone experience this or know what it could be?
I also installed LED headlights with the Proper resistor and LED fogs. Any feeback would be appreciated Last edited by Johnny5; 07-24-2022 at 07:28 PM. |
07-24-2022 | #2 |
Re: Cruise control shutting off when using blinker
When you turn the blinker on are all the exterior lights functioning as expected? Seems the turn signal and brake light circuits may be cross wired.
07-25-2022 | #3 | |
08-03-2022 | #4 |
I think there is a problem with the wiring traveling down the column for the cruise. Have you done anything on the column?
