Old 07-21-2022   #1
Young1
Young1's Avatar
Default Don?t hit rev limiter.
1990 car. 1991 engine with correct 1991 Haibeck chip. My project idles well and has great drivability. It won?t hit rev limiter in first and second gear. It flattens at 5,000, gets to 6,500 and stops. TPS is .58 at idle. FSM limit is .59. Fuel system pressures are Ok. Secondaries are working I can feel the kick at around 3,500. Vacuum system has been thoroughly checked and tested. Throttle blades visually open 100 percent and air cleaner is new. I have no codes on scanner and no check engine light. It is not making that strong pull of power to rev limiter. What other parameters should I check? Need help. I have a buyer for the car.
Steve Young
Second Owner
SOLD
SOLD
Old 07-21-2022   #2
tccrab
tccrab's Avatar
Default Re: Don?t hit rev limiter.
Maybe your accordion air duct is collapsing and restricting your air flow.
If you're sure of fuel and spark, then it's gotta be air.
Crabs
Old 07-21-2022   #3
Young1
Young1's Avatar
I have duct supports inside it and I ran it without air cleaner or accordian also. Hmm
Steve Young
Second Owner
SOLD
SOLD
Old 07-21-2022   #4
efnfast
I'm thinking the secondaries are not opening.
Old 07-21-2022   #5
tccrab
tccrab's Avatar
Or the butterflies are opening, but the secondary injectors aren't squirting fuel.
It's two different operations.
Kinda makes sense, you feel the kick at 3.5k as the butterflies open and extra air is let into the heads, then as RPMs climb the engine goes lean because there's no extra fuel.
Crabs
Old 07-21-2022   #6
I?m with collapsing intake duct.
Old 07-21-2022   #7
precast1
Did you get it figured out? Sounds like maybe not enough fuel? Getting closer to PA.
Sent from my SM-G986U using ZR-1 Net Registry mobile app
precast1 is offline   Reply With Quote
Old 07-22-2022   #8
Young1
Young1's Avatar
Last night I found an obstruction in fuel pressure line. Blew that out and replaced hose assembly. No difference. Tccrab description is exact. It has air to make higher rpm but not fuel. I spliced the power key wires together. Full power light came on but no full power. I removed 91MY Haibeck prom and installed a 90MY SGC prom. It ran hard and fast full power to rev limiter! Once. Next time I tried check engine light came on which means it threw a code. I will check out that code tomorrow. Making progress. I least I know it WILL make full power. Also I need to diagnose the non working cruise control.
Steve Young
Second Owner
SOLD
SOLD
Old 07-23-2022   #9
I?ll bet its a code 61. Lean condition.
Old 07-23-2022   #10
fastpace
On the cruise control front there's some good threads on the troubleshooting. Mine was a hole had worn in the vacuum line running to the cruise diaphragm on the drivers side. There's also a vacuum line that runs to a clutch pedal switch too.
fastpace is offline   Reply With Quote
