12-10-2021 | #1 |
Faulty oil pressure sensor?
Ever since I got my '90 ZR-1 seven+ months ago the oil pressure has read ~70 psi as soon as the car starts, at idle, at any throttle speed with no more than a tiny 2-3 psi fluctuation if it revs up.
I assume this means the OPS has bit the dust and should be replaced. And that is the sensor standing upright to the left of the oil filter, correct? Anything else that could cause this, anything else I need to look at? The connection is clean inside and I doubt a poor electrical connection is the issue. Do I bother trying to measure the resistance at various engine speeds or do I just replace it for < $40? Car otherwise runs great with no issues. |
12-10-2021 | #2 | |
Re: Faulty oil pressure sensor?
12-10-2021 | #3 |
That's my intention. I'll let you know what happens when I get it done.
Was just looking for a little support or other advice. |
12-11-2021 | #4 | |
Key indicators of failure are that they all peg or the drop showing less that 0 oil pressure. Correct it's upright of the oil filter.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-11-2021 at 12:19 AM. |
12-11-2021 | #5 |
I believe there are multiple OPS's out there. I think there is a specific part# to order if you want your analog gauge to read pressure more in the normal zone than standard replacement OPS that tend to show the pressure higher than the original gauge. I don't have the actual part number handy but I am sure someone here will have it.
12-12-2021 | #6 |
My OPS is black so I assume it's been replaced at least once. Is the socket size still a 1 3/6" if it was replaced, or would/could a PO replace it with a 1 1/16" sensor?
Are the thread sizes that screw into the filter housing the same, just the size of the base to grab on to is different? It's hard enough to get a sensor socket without having to buy 2 of them. Last edited by mlipmd; 12-12-2021 at 03:31 PM. |
12-16-2021 | #7 |
Is there any difference in the sensors with the base either 1 1/16 in. size vs. 1 3/16 in. size? Will either sensor work the same in my '90? Seems like all the sensors are 1 1/16 in. in size now and all the suppliers say they are all compatible with the '90-95 LT5s. If so,
now I have to get the 1 1/16 size socket as the 1 3/16 I got is too big to fit what's in my car or the new sensor I was sent. |
12-17-2021 | #8 |
Posted also on the Corvette Forum - any thoughts on here?
So I put in a new AC-Delco OPS and the oil pressure still reads ~70 on startup, then down to maybe 60 after it warms up, back to 70 on revving up the engine a little. Maybe that's due to a 40 wt. oil in there instead of 30? Or the OPS is not properly calibrated for the LT5. Gonna leave it like that for now. As another aside - how many wires are in the connector to the OPS? Mine just has one wire leading into the top of the sensor, I assume that's just to measure the resistance inside? Last edited by mlipmd; 12-17-2021 at 12:58 PM. |
12-18-2021 | #9 |
FYI- if anyone cares-
Went for a 20 mile ride today and the OPS and the oil temp sensor seem to be working OK and I learned a few things too. First of all, the reading of 70 on startup is what the last reading was on the analog gauge when you last shut off the engine, before it starts. If you turn the key to OFF again and then to restart, the gauge will read 0 before the engine starts, then the pressure reads 70. This is with cold oil. Because of the volume of oil in these cars (~9 qts.), it takes a while for it to warm up and reach operating temp - maybe 10 miles of driving or so. After the car is warm, the idle pressure in my engine drops down to the 30-40 range on my gauge (about 1/3-1/2 way up the scale), and then goes up to 60-70 when revved up or driving. And my oil temp only goes up maybe to 1/4 the way up the gauge, also takes 10 miles of driving or so to get up to there. So everything seems to be working as it should and I never really noticed that before, that it takes so long to get the oil up to temp. |
07-14-2022 | #10 | |
