Old 04-12-2022   #1
Jetjock
Jetjock's Avatar
Default Code 31
Now that I got my car started and relocated to my new house, I can pay more attention to it. After I got it here, I had no less than 3 items on my DIC. One is easily fixed: Put air in the tire. The second one is also kinda easily fixed: One of the teeth on the ride select is missing a tooth on the wheel on top of the shock. I had it out looking at but for whatever reason at the time, I just put it back in. The last one is boogerbear as my dad would call it. Don't ask!
I got a code 31. I went down this rabbit hole before. According to the diagnostic that I performed, it was the ECM. After going through all that, it still shows the 31 code. It pointed to the cam sensor. I did buy one from someone on here and it didn't work. Engine wouldn't even run. I put back the old one and the engine would start but won't accelerate. Marc Haibeck told me that it could be for something else. Any ideas.
Roy
Roy L. Carman
If I feel the need for speed,
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Old 04-13-2022   #2
Young1
Young1's Avatar
Default Re: Code 31
Jagpanzer has made some camshaft sensors that work. I have probably 25,000 mikes on the prototype. There is much to search and read on the subject. They are NLA.
Steve Young
Second Owner
SOLD
SOLD
Old 04-13-2022   #3
Jetjock
Jetjock's Avatar
Default Re: Code 31
I saw that in a previous post. Problem is that they didn't work on my car. Could barely crank the engine. I talked to Marc about it and, basically, it either the ECM or the sensor. The ECM was done by Marc so I'm pretty sure the ECM is good. He did mention about shimming it with a .6000 washer. Problem is that I looked around for a washer with that thickness and I couldn't find any. None of the places around here don't carry it. Where did you get yours? I do have one of his sensors.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 04-14-2022   #4
viper107
viper107's Avatar
Default Re: Code 31
also throwing a cam code could be a misfire fault
Old 04-18-2022   #5
Jetjock
Jetjock's Avatar
Default Re: Code 31
Where can you find a .6000 washer?
Roy
Roy L. Carman
NCM Lifetime #1468
Old 04-18-2022   #6
carter200
carter200's Avatar
Default Re: Code 31
Roy
Roy,
I?d go to Lowe?s and get a 5/8 (.625) one . Take a sheet of fine metal sand paper and shave off the .025.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 04-18-2022   #7
G8nightman
G8nightman's Avatar
Default Re: Code 31
What year is your car?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 04-18-2022   #8
Young1
Young1's Avatar
Default Re: Code 31
The shimming is for the crankshaft sensor and to my knowledge only applies to the 90 model year. It?s funny that there is a code 31 for the Camshaft sensor but there is no factory code for the crankshaft sensor. I agree that misfires can show up as a 31 code and I would replace the crankshaft sensor with one from Jerrys. It is a direct replacement fit. If you buy one from the auto parts store you have to grind them to fit properly to the engine block. My engine was giving me trouble and my crankshaft sensor tested perfectly per the factory service manual but upon replacement took care of the problems. Use a bit of RTV too. They are easy to change out.
Steve Young
Second Owner
SOLD
SOLD
Old 04-19-2022   #9
Jetjock
Jetjock's Avatar
Default Re: Code 31
92
Roy
Roy L. Carman
NCM Lifetime #1468
Old 04-19-2022   #10
Jetjock
Jetjock's Avatar
Default Re: Code 31
I'm working with Marc Haibeck on this since he redid the ECM. The ECM doesn't have any issues so it must be the cam sensor. I did get a Phil cam sensor and it didn't work in my car so I put the old one back. It starts up fine and runs good until it gets warmed up and won't accelerate and it throws the code 31. We'll see.
Roy
Roy L. Carman
NCM Lifetime #1468
