Old 12-11-2021   #21
Default Re: GE Nighthawk Install
Originally Posted by michael857 View Post
I converted to GE nighthawks in 2017 by using the elegant method from Circuit Doctor and found it easy, worked well, and didn?t involve pulling apart the dash or turn signal switch to ground out the green wire.
https://www.corvetteforum.com/forums...-solution.html
I added one relay next to the OEM one. Added one ground wire and did not cut wires. Everything works as it would stock
