Old 10-06-2021   #1
moesvette
moesvette's Avatar
Default Antenna Bezel Replacement
It appears that the rubber antenna bezel for our ZR1's are no longer available, but I am curious as to if anyone has found an acceptable replacement. Mine is torn, and beyond trying to make one, I was curious to know if anyone has found an acceptable replacement? Thank you.
1990 Red/Tan Mark Haibeck Chip/B & B
moesvette is offline   Reply With Quote
Old 10-06-2021   #2
Default Re: Antenna Bezel Replacement
No acceptable alternate I know of. I suggest reaching out to Mirrock Corvettes for a salvage part.
Old 10-06-2021   #3
Jagdpanzer
Jagdpanzer's Avatar
If someone can supply a spare I can investigate making a mold for reproductions in soft urethane.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 10-06-2021   #4
Phil,
I have a spare you can use will you need the nut that holds it on also.
send me a PM
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-06-2021   #5
Originally Posted by We Gone View Post
Phil,
send me a PM
Is there a nut? I though it was a rubber piece with circular notch to hook on to body panel.
Old 10-06-2021   #6
The one I have is off a 91 it has a notch for proper alignment but it is threaded and held in place by a large nut assembly sorry don't know why the pic is side...
The parts book does show but not the nut maybe this is an aftermarket part, I just removed from the car today. Sorry this is some aftermarket part....
Black rubber part on top # 14104620
Steve
1990 Red/Red #1473
Old 10-06-2021   #7
Interesting... I have a spare OEM. If I can find it, I?ll post a pic.
Old 10-07-2021   #8
Young1
Young1's Avatar
Is there a way the base car bezel can be modified to work?
Steve Young
Second Owner
SOLD
SOLD
Young1 is online now   Reply With Quote
Old 10-07-2021   #9
I haven't tried but probably not. Reason being, relative to vertical (antenna), canting of the rear quarter side ways are different between standard C4 and ZR-1.
Image posted by We Gone looks to be for C4 between 84 to 87 based on google search image.
Old 10-07-2021   #10
the one in the pic was on a 91 ZR-1 that I parted out it looked to fit right .. but the antenna was not on the car I have a standard C4 bezel and yes the slant is the same as the pic.
My bet is if the aftermarket antenna had been on the car it would have been canted as you stated.
Steve
1990 Red/Red #1473
