Old 06-18-2021   #1
Tommio RS
Default Oil pressure issue?
Hey everyone, I come with a simple question.
Is it normal to have oil gauge behavior like this.
https://www.youtube.com/watch?v=rdnvnwBwlhw
The situation is when warm like coolant temp is 90c and the oil temp is over 50c or so the gauge will dance around like in the video. This only started happening more and more as last year. When the cars oil and coolant are at the same temp around 90c the oil pressure gauge will sit half way between half and 0, so 20psi at idle. The moment your tap the gas the gauge will shot up over half if not to the max and stay the way when driving. I have NO clue if that is normal oil pressure or not. I will say though. When i 1st bough the car 3 years ago the engine oil was no joke some sort of thick goo like gear lube. Since then i have ONLY ran Amsoil 10w40 AMO.
My best guesses are the sensor to the gauge in the car could be on it way out, the gauge cluster could have some error, the engine does not like the amsoil 10w40 amo OR worst cause is oil pump/ internal bearing clearance issues.
Tommio RS is offline   Reply With Quote
Old 06-18-2021   #2
dredgeguy
dredgeguy's Avatar
Default Re: Oil pressure issue?
Mine does the same. When I am on the gas pressure is high and when idling it is in the middle.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-18-2021   #3
aod
Your oil pressure sensor may be on its way out. Remove the connector and see if there is oil in there. If so, it is definitely on its way out. You can get a replacement here:
https://www.jerrysgaskets.com/sensor...new-90-95-9c5/
A basin wrench makes this job easier.
aod is offline   Reply With Quote
Old 06-18-2021   #4
32valvesftw
I have a Jeep that was doing that, the fluctuations increased until I smelled oil and noticed oil seeping from the sensor. So yeah, check that sensor.
Old 06-18-2021   #5
Tommio RS
OK! That's all some really good information.
So my engine is not going to blow up thank goodness!
So its not the end of the world seeing the gauge in the middle of 0 and 1/2!
So what im going to check out is the oil pressure gauge sensor connector and see if there is oil inside the connector and the sensor body. And you say a basin wrench will make life easier lol, like for plumbing?. I guess you cant just jam a deep socket over the entire sensor and un bolt it?
Old 06-18-2021   #6
aod
With no load on the engine, idling my oil pressure gauge reads right in the middle when it is at operating temp, so I don't think that's a big deal. What I noticed was the needle on yours was bouncing around a bit. That's indicative of a sensor on the way out. And yeah, the basin wrench is for plumbing. It has been a while since I replaced mine, but I don't think a deep socket would have fit over it. I scratched my head for a bit and then just grabbed a basin wrench and tightened it up. It has been good for around 10 years now.
Old 06-21-2021   #7
Tommio RS
Ok, I removed the oil pressure sensor connector and checked for oil. I didn't see any what so ever in the connector or switch. So i will just replace the sensor just because. Also its a 3 pin connector with one wire? I guess it ground through the engine or something.
Also don't they make a socket for just such a job?
https://www.amazon.com/Lisle-13250-P.../dp/B0002SR2RY
That is just one of many i have found.
Old 06-21-2021   #8
TX '90 ZR1
TX '90 ZR1's Avatar
Yes, there are sockets that are designed to remove sensors. Most auto parts stores will have one.
Kenny
1990 #442
Old 06-21-2021   #9
aod
I have one of the oil pressure switch sockets like the one in that link. Mine isn't deep enough to get this specific sensor out though.
Old 06-21-2021   #10
Jagdpanzer
Jagdpanzer's Avatar
Here is the one that'll do it
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
