Old 05-10-2021   #1
TX '90 ZR1
TX '90 ZR1's Avatar
Default Power Steering Pump Pulley
While verifying my findings on a noise from a driven accessory, (In a separate thread "Water Pump Rattle?), I notice the power steering pump pulley is not running exactly true. Have not noticed before and am experiencing no issues from this. Paying such close attention to the driven accessories brought this to my attention.
I estimate it is about 1/8" from running true.
Normal ? Maybe an issue?
What are we doing for pumps if one is needed?
I think Jerry has pulleys.
Thanks for everyone's help in advance.
Kenny
1990 #442
Old 05-10-2021   #2
Default Re: Power Steering Pump Pulley
Runout by 1/8" is not normal. I would check and make sure the pump is mounted correct.
If a replacement pump (I believe power steering pump is ZR-1 specific) cannot be located, my suggestion is to have Turnone rebuild the pump.
https://turnonesteering.com/
Old 05-10-2021   #3
TX '90 ZR1
TX '90 ZR1's Avatar
I thought it was out of the ordinary also. Can't believe I had not noticed it before! I'll do a little more investigating the cause when I am changing the water pump, hoses, etc.
Thanks for chiming in.
Kenny
1990 #442
Old 05-14-2021   #4
Great White
Great White's Avatar
I figured I'd back up the Turn One recommendation:
I've had some experience with a Turn One power steering pump. I can comfortably say they are one of if not the best power steering pumps on the market. I had one of their modified pumps on an '00 Z-28. It worked flawlessly, ran cool, and gave very good road feedback.
Great White is offline   Reply With Quote
Old 05-14-2021   #5
jss06c6
Has the pump been pulled before? If so, someone didn't seat the pulley all the way. It will definitely wear out the belt, which will fail eventually. Make sure you have the right pulley too.
Old 05-15-2021   #6
TX '90 ZR1
TX '90 ZR1's Avatar
Thanks for the feedback Steve.
Pump and/or pulley have not been off since I have had the car. Not sure before I got it.
Will be checking out the cause next week when I have it apart for the water pump change.
Kenny
1990 #442
Old 05-15-2021   #7
carter200
carter200's Avatar
Kenny,
www.rockauto.com
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-15-2021   #8
New GM NOS OEM
(Used are also available)
https://www.jerrysgaskets.com/pulley...401.1592494539
Old 05-15-2021   #9
TX '90 ZR1
TX '90 ZR1's Avatar
Originally Posted by carter200 View Post
Hey Carter,
Thanks. I need to do a bit more checking to find the "for sure" issue. Should happen next week.
Good to hear from you.
Kenny
1990 #442
Old 05-15-2021   #10
TX '90 ZR1
TX '90 ZR1's Avatar
New GM NOS OEM
Thanks Jerry. I had noticed you had pulleys if that is what I need.
The shipment from you (water pump, hoses, etc.) is scheduled to be delivered today, so will start working on it in a day or two.
Appreciate all your support.
Kenny
1990 #442
