04-14-2021 | #1 |
93 Zr1 Clutch Slave Cyl
I need to replace or rebuild the clutch slave cylinder on my 93 ZR1. Looking for input from others as to what they have done. I would prefer buying American made parts if possible. Your input would be most appreciated. Thanks Ellis
04-14-2021 | #2 |
Re: 93 Zr1 Clutch Slave Cyl
Someone may be holding onto a NOS part that you could buy. Another option is to reach out to Bill Bourdeau as he used to rebuild the masters but possibly the slave as well.
http://www.zfdoc.com/ Zip Corvette has this as a replacement. Appears to be the steel version with the skinny mounting flange and not a cast iron replacement. https://www.zip-corvette.com/91-96-c...kaAjz3EALw_wcB |
04-14-2021 | #3 |
Thank you. I will contact ZFDoc
04-21-2021 | #4 |
Rock Auto carries the cast iron clutch slave cylinders you want.
