Old 03-12-2021   #1
bmarcum
Default Need an oracle! Low speed miss on cylinder #1 only.
Okay sorry for the lengthy post but I need some help. I have a LT5 shop manual but I can?t find it at the moment. I have a 1990 ZR-1 #103. The Z has about 109K miles on it at the moment. This is my second Z and I do love these cars.
My Z has developed a low rpm ignition miss. It started on the interstate in 6sp gear lug. I hadn?t replaced the plugs in a while so I replaced the plugs that evening (not expecting that to be the problem). I pulled the intake the next weekend and found the wire resistance off (9K) so I replaced all the wires. The wires had 30K on them and needed replaced anyway but didn?t fix the problem. I recently changed the coils to MSD 8224 coils.
Now comes the scary part. The miss is intermittent. Sometimes it does it misses cold, sometime it misses hot, and sometimes it doesn?t miss for a while. But it never dies or has starting problems, just a low rpm miss. You can hear the miss at idle, so I started pulling plug wires and found that the spark on cylinder one was weak/intermittent. All connectors on the ignition module are original but seem to be clean and holding tight. So I replaced the coil for cylinder 1/6. Also didn't fix the problem.
How does the ignition system fire cylinder 1 vs 6? It seems to only miss on cylinder one. Also when the rpm?s are above 3/3.5K it pulls through the miss and run well. When I pull the wire on cylinder 6 (same wasted spark coil) it has a strong spark. This really confuses me. It only misses on cylinder number one? Does the computer/ignition module give a separate command for cylinder 1 vs cylinder 6? I thought in the wasted spark ignitions that it just fired the coil on the same command for cylinder 1 and 6.
All other cylinder have good spark at idle. What could I be missing? If the timing pick up was bad, it wouldn?t always be cylinder one missing. Has anyone seen an Ignition module weak on only one cylinder? Can the computer cause this? Anyone have an ignition module for borrow/purchase? I know I am asking for a very rare part. Any thoughts? I am stuck at the moment. The way the problem started, I don?t think it is a control wiring shorting. I also don?t know how to test the ignition module or wires. Any help is appreciated.
Thanks
Brandon
bmarcum is offline   Reply With Quote
Old 03-12-2021   #2
Default Re: Need an oracle! Low speed miss on cylinder #1 only.
Original injectors?
Old 03-12-2021   #3
bmarcum
No I replaced the injectors 4ish year ago. They had failed due to the ethanol issue. Also the computer has been replaced at that same time.
Old 03-13-2021   #4
MAP sensor hose checked, etc?
Old 03-13-2021   #5
bmarcum
Yes I believe the map hose is fine. How would the map cause an ignition miss? I am only seeing a weak spark on cylinder #1 intermittently.
Old 03-13-2021   #6
Reading the manual
-One interesting point is a faulty vehicle speed sensor can cause a high speed fuel cutoff(as in the vehicle thinks its going faster than it is)
Other points were discussed, bad injector, injector harness, ignition ...check compression, etc
Old 03-13-2021   #7
You know its weak spark or think? Bad map sensor hose will cause stumbling and missing ......
Surprised there are no codes, you need a tech one or scanning software to read what the engine is doing when it happens
Old 03-13-2021   #8
bmarcum
I noticed the miss driving down the interstate in 6th gear at low rpm. Then it became common. I was able to identify that it is on cylinder #1 by pulling all plug wires one at a time. It was easy to see that the miss is cylinder #1, but that is where I am stuck. I have replaced ignition coils, plug wires, and plugs. If this were a distributor engine (90's fords were notorious for similar ignition module problems but not a single cylinder) I would put a module in without thinking about it. Has anyone seen a ignition module have this symptom?
I will check/ replace the map hose tomorrow.
Thanks
Brandon
Old 03-13-2021   #9
Corvette95
Corvette95's Avatar
You say you replaced the coils recently. What is recently and did this happen before or after the coil change? Also,have you checked it in a dark environment for arcing? How did you determine weak spark / no spark on #1?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Corvette95 is online now   Reply With Quote
Old 03-13-2021   #10
FUEL - AIR - SPARK Take NOTHING for granted. Just because something was replaced, it is not proof that "something" didn't go bad again!
If, as you say, the miss is narrowed down to a particular cylinder I'd want to get it up to operating temp and measure injector resistances again. (BTW, you replaced the injectors...with what, exactly?).
And, too, I had a miss on one cylinder that a compression check lead to a burnt valve (stemming from a bad injector, I believer!) Have you done a compression check yet??
