Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 01-08-2021   #1
staminqia
staminqia's Avatar
Default Service parts identification sticker
My center console at some point was removed and replaced and the sticker is no longer present. I asked several outfits including corvette museum for replacements and unfortunately no one can reproduce them. Has anyone tried to reproduce them, size, font style? anyone have a template in word that I can use. I can recreate them but it will take a ton of time to match font style and spacing but I was wondering if anyone on here has had this issue and how did you go about replacing it??
attached is my build sheet.
thanks
Anthony
staminqia is offline   Reply With Quote
Old 01-30-2021   #2
TucsonZR1
Default Re: Service parts identification sticker
To have it judged you really dont need it. The NCRS requires a copy of the Build Sheet be sent to the Team Leader from the Museum. It will when given to you when your car is Judged.
Old 05-11-2021   #3
staminqia
staminqia's Avatar
I spent many hours reproducing these SPI code stickers. I could not find anyone to redo these when you don't have the originals so I did them my self. I redid the air bag and RPO sticker, if anyone needs a set I would need their RPO codes and I can reproduce them for you.
What do you think? they look pretty good compared to the originals.
Old 05-11-2021   #4
TucsonZR1
Be careful. If the car goes to a major auction and is found to be reproduced, the car can be confiscated. Having the build sheet is all that is needed especially on a ZR1 that has all RPOs already.
Its like reproducing a C2 Trim Tag.
Old 05-11-2021   #5
staminqia
staminqia's Avatar
I have the build sheet also, I just wanted to have the stickers too.
Old 05-11-2021   #6
Joelbbvette
Joelbbvette's Avatar
See PM I just sent you.
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 05-11-2021   #7
conesare2seconds
I think you will be fine since you have the broadcast sheet too. Nice job with the reproduction.
Old 07-12-2022   #8
bob@tradeshowconsulting.c
nice job with the reproduction parts label. Can you do one for me ?
bob@tradeshowconsulting.c is offline   Reply With Quote
Old 07-12-2022   #9
dredgeguy
dredgeguy's Avatar
Well done Anthony, nice to know we have your talents in the group!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-12-2022   #10
staminqia
staminqia's Avatar
Do you know all of your RPO codes?
If you go to this site www.compnine.com and create a login you can get all of your RPO codes via your VIN.
From there I can then create one for you. I will send you a PDF of the label then you will have to print it on a sticky back sheet of paper, cut it out carefully and then your good to go.
let me know
Anthony
