#1 | |
![]() Join Date: Aug 2015
I then match the lowest primary with the highest secondary for a cylinder pair. I continue this sequence until I have the highest primary with the lowest secondary injector. I then assign the highest combined flow rate pairs to #8 & #7, working my way forward to #2 & #1 which will have the lowest combined flow rate. I also had them flowed at 50 psi vs. 43 psi. Obviously you can't use injectors that are way off! My experience so far delivers nice fuel balance across the cylinders with optimal combined flow when secondaries are kicked in (or when running on engines with secondaries deleted). Bank to bank fueling seems to be closer as well (read BLM left and right) provided your O2's are good.20201102_055510.jpg20201102_060041.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app Last edited by jss06c6; 11-02-2020 at 07:22 AM. |
![]() Join Date: Nov 2011
NGK TR7ix. Sorry, I guess there were two "as above" plugs.
So what heat range are you all running? I?ve read that Iridiums run a bit hotter than equivalent copper plugs. I?m trying out BKR7Es right now which SOTP seems to like. Also appears to have helped w random knock.
#4 | |
Sent from my SM-G950U using ZR-1 Net Registry mobile app |
#5 | |
Hib, As you can see from the quote, I stated I had read that equivalent iridiums ran a bit hotter. I interpreted that as having a hotter spark. |
![]() Join Date: Mar 2007
Be aware of counterfeit NGK and Denso spark plugs when shopping on the internet. Try google fake spark plugs. Use an authorized dealer so you know what you getting.
Used FR1LS 035 and now Ngk bkr7e-11 044. Never logged to compare but runs fine with both and my driving style. Thomas Last edited by Rodder; 11-04-2020 at 07:55 AM. |
#7 | |
Have u looked to see how they are burning? |
#8 | |
![]() Join Date: Jun 2005
"Rodder" is correct. There are a lot of fake NGK and Denso plugs sold on the Internet. Solution: buy NGK and Denso from legit retailers of those brands.
#9 | |
A plug that is a hotter heat range does seldom means it makes a "hotter" spark. Iridium tipped plugs in a given heat range do not run "hotter" than a non-iridium plug of the same heat range.
