Old 07-23-2020   #1
Oakhurst
Default Old style fuel pump?
Having what I think is a fuel delivery issue with my 1991, 30K miles. Changed the fuel filter, same problem, starts right up, runs a few seconds (longer if you wait longer between starting attempts) then stalls. Pulled the fuel pump after watching videos, and my pump has 2 separate pumps on the same assembly. manual testing shows one works, one does not. It is not the same pump I see on the videos. Replacement pump looks like the same pump (one pump only) in the videos. Is my old one now being replaced with this new version?
Oakhurst is offline   Reply With Quote
Old 07-23-2020   #2
CamP
Default Re: Old style fuel pump?
The ZR-1 has two pumps.
CamP is offline   Reply With Quote
Old 07-24-2020   #3
Oakhurst
Napa shows this single pump for the LT5. My shop used the proper vin and this is the pump that was listed.
Old 07-24-2020   #4
G8nightman
G8nightman's Avatar
Lt5 uses two pumps a primary and secondary replace the bad pump or both and put it back in.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is online now   Reply With Quote
Old 07-24-2020   #5
Oakhurst
Are both pumps in the fuel tank?
Old 07-24-2020   #6
G8nightman
G8nightman's Avatar
Yes on the same assembly in the tank
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 07-24-2020   #7
Oakhurst
I will start looking right now. Any suggestions where to find one?
Old 07-24-2020   #8
Oakhurst
What do you think of the TI Walbro Ligenfelter dual pump?
Old 07-24-2020   #9
CamP
Rock Auto has everything you need with the exception of the o-rings for the nine bolts that attach the sending unit to the tank.
You'll need 2 new screens.
Acdelco TS1 short
Acdelco TS2 long
Gasket
Spectra L0148
2x Pumps required.
Options include:
Acdelco EPS148 -includes new clamps (made in Brazil
Airtex E320 (made in china)
There are several others that will work.
O-rings - viton 5mm x 8mm
Grainger #1RHN7
Old 07-24-2020   #10
Ccmano
Ccmano's Avatar
Replace both pumps while your in there. Your dealing with 30 year old parts. Don't bother with high performance pumps unless the car has been modified and has over 500hp. RockAuto.com and JerrysGaskets.com have a good selection. I've had good luck with the "Performance Electric" Brand Rock sells. Can't go wrong with Delphi. Ultimately they all come from China. Replace the plastic hose clamps on the assembly with stainless steels ones as well. If you don't have one, buy yourself a Factory Service Manual and read up on the cars systems and how they work. The fuel system (amongst other things) on an LT5 is unlike any other.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
