Old 06-15-2020   #1
rush91
Default Ever wonder if a 30 year old spare works?
On my way home from a Sunday drive, stopped for gas and noticed my passenger rear tire was flat.....I was about an hour from home, I don't have AAA or a road side tire kit. So out comes the 30 year old dounut. Changed the tire and drove about 60 miles home. No issues at all. The spare was my hero of the night!
Old 06-15-2020   #2
Default Re: Ever wonder if a 30 year old spare works?
Happened to me once with the Quasar '93 in the late '90s. The TPS light came on and I used the spare and put the big tire in the tire bag. Boy did it look funny with a 13" wide tire on one side and a 4" wide one on the other! When I got to a gas station they discovered a 1/2" mending plate about 2" long embedded in the tire sideways; tire was toast. When I got the diagnosis I called my local tire dealer for the 315 Goodyear. When he called back a while later he said, "I have good news and bad news for you. The good news is there is one available in the country, in a warehouse in Indiana. The bad news is that it is the most expensive tire we sell." Oh well. One thing to note: The spare is supposed to have 60 psi of pressure, so it is always a good idea to check it occasionally if you still carry the spare. Just in case. Once I checked it and it was down to 25 psi.--Bob
Old 06-15-2020   #3
Stingray1967
Stingray1967's Avatar
Wow, you got lucky!! My original spare that I looked at after buying the car last November wouldn't hold air to save its life. Glad you made it home safely!
1967 Corvette convertible, L79, 4 speed, red / black / white top
1994 Corvette ZR-1, white / black
NCRS North Central Chapter Judging Chairman
Stingray1967 is offline   Reply With Quote
Old 06-15-2020   #4
On my Polo '95 in 2016 its original spare tire still held 60 pis of air, at least for a pretty long time. I wonder if your spare's rim might be corroded. Ever have a tire shop dismount it to see? If the tire isn't cracked that might be the issue, as might a failed valve. Had a leaky valve on one of the regular tires my '95. While I would not want to drive very far on a 30 year old doughnut spare, it is still good to have in an emergency. Assuming you still have the spare tire carrier in place. --Bob
Old 06-15-2020   #5
Stingray1967
Thanks Bob, here is what I know. 1994 ZR-1, 21,500 miles when I bought it. It looks for all the world like the original spare tire and wheel combo. It has the correct markings. I didn't check the date code on the tire, but believe it to be original.
I took it out of the spare tire housing and it had decades worth of road dust on the tire. I put the tire in my garage sink to clean it after airing it up. It "spat" water at me around the circumference of the wheel (right on the bead) for roughly 35-45% of the circumference on one side, and about half that on the other side. In other words, it leaked like a sieve.
I agree that having a spare tire is a good idea. Here is my glide path.
Swap the front spring on the car (it is sitting too low has a base coupe front spring in the car right now).
Swap the four road tires with recently acquired Goodyears.
Have the car aligned.
Address the spare.
I guess I could have the shop address the spare tire right now. Nothing holding me back from that.
Old 06-15-2020   #6
Mystic ZR-1
Mystic ZR-1's Avatar
OMG...
Put on the spare and screw up the tire crayon markings they
put on at the factory 😀 What would NCRS say?
Murphy?s law says you?ll have the flat tire at the worst
possible time and location...
Carry a can of tire goop, a tire plug kit with pliers to pull out the nail
and a cheap 12v compressor.
Of course none of this is any good if you
rip a hole in the tire, refer to Murphy?sl law above...
AAA card, just like your AMEX card, don?t leave home without it.
Old 06-15-2020   #7
rush91
Thanks! I got very lucky, as in there was a gas station at the next exit. She started swaying that butt back and forth, like the tire was loose or ready to fall off... I just had them mounted last Thursday and didn't see any nail or screw in the tire after I got it off. So not sure what the issue is yet...?
I busted out the owners manual out of glove box and went step for step. Kind of neat how GM includes everything one needs, and where they stored things at. I also noticed, that the tire says " Must inflate to 60 PSI".....But our tire gauge that was original to the car, only goes to 48 PSI lol....
Old 06-15-2020   #8
rush91
Originally Posted by Mystic ZR-1 View Post
OMG...
That's 30 years worth of patina
Old 06-15-2020   #9
BigJohn
BigJohn's Avatar
I have a cousin named Patina, but she is older than 30!
Old 06-17-2020   #10
ZWILD1
ZWILD1's Avatar
I have really had good luck and never used the spare in any of my Corvettes. This includes trips to Bowling Green with the cars. My 96 was a daily driver for at least 3 years. I removed my spare and cleaned it up with car wash preserving the markings and installed it back just the way it was. I took detailed picks of it when I removed it so I could reinstall the jack just the way it was placed at the factory. The Michelin PS'2 I purchased from Tire Rack actually come with a road hazard policy. The T155/70D17 is still available as it is used on new Toyotas and Lincolns.
I worked for an independent tire dealer from late 82 until 1990. I saw some crazy stuff pulled from tires drivers ran over. Things like 2x4's, large portions of lawn mower blades, large bolts that went in head first, sections of glass bottles, and just about anything you can think of. I prefer to patch a tire when it's in the center section of the tread. We used a cone shaped plug installed with a gun. Although I have seen the plugs cut by the tires steal belts over time. Also with a puncture that breaks the tires steal belts a separation may develop. When you strike a curb with the side wall a bubble or bulge may develop. This is caused by the inside layer of the tire breaking. We call that an impact abrasion which voids the warranty as does any puncture. I highly recommend getting a road hazard policy especially for tires that cost a couple hundred dollars.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
