Old 01-24-2020   #1
lfalzarano
Default Condensation on AC lines
Today it was 46 degrees and took the Z out for some exercise. When I returned and popped the hood to connect the trickle charger, I noticed the AC lines were dripping. I know on a warm day with the AC on water will accumulate under the engine.
Never noticed this before and wondered if this was normal. Just curious from the attached photos.IMG_3817.JPG
There are no other noticeable issues in the engine compartment.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 01-24-2020   #2
Carnutdallas
Default Re: Condensation on AC lines
Normal. AC was working, but humidity in the air. If it was on auto setting of climate control, then compressor was on, even if blend door was more on the heater side.
Sent from my iPhone using Tapatalk
Carnutdallas is offline   Reply With Quote
Old 01-24-2020   #3
viper107
viper107's Avatar
yep totally normal, cold lines from compressor being on and a big o hot engine in there
Old 01-25-2020   #4
lfalzarano
Thanks guys!
Old 01-26-2020   #5
dredgeguy
dredgeguy's Avatar
Man that is a relief, I had the same concerns. I went to cars and coffee and when I opened the hood lots of condensation on the AC lines. Glad to hear it is normal, thanks!
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
dredgeguy is online now   Reply With Quote
