![]() Join Date: Nov 2007
Are the ones inside the fuel rail, (there are 4) the same as the rest? I got Jerrys O ring kit and have 4 that I cant see where else they go...other than inside the fuel rails...
https://www.jerrysgaskets.com/seal-s...n-90-95-7-5d8/ Thanks, John
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] Last edited by 32valvZ; 01-14-2020 at 05:43 PM. |
![]() Join Date: Aug 2015
![]() Join Date: Jun 2006
Since you have a 90’ you should have the 2 different sizes for the injectors themselves. 8 larger for the Primary Injector lowers that mount into the injector housing itself. 24 smaller for the 16 upper of all injectors and 8 lower for the secondary injectors. Then a smaller set of 2 for the fuel line to the fuel rail connection. These last ones are also used for the pipes, rails and regulator connections. That’s probably what your seeing.
H ![]()
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
So Phil rebuilt my FPR... I had Jerry send me a FPR O ring kit... this is not for injectors.... only the lines that go to the FPR.... Theyre all the same size. Inside the actual fuel rails, there are O rings... I wasnt sure if theyre the same as the ones where the lines plug into the FPR. I have 4 left and there are 4 bores, 2 in each rail that have O rings inside them...
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] Last edited by 32valvZ; 01-14-2020 at 05:44 PM. |
Yes, I believe all the fuel rail o-rings are the same size. I believe there are 9 total O-rings for the rail/regulator.
H ![]()
I was skeeered to pluck them out of the rail with a pick and ruin them if they were different...
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
