Old 07-14-2019   #11
lfalzarano
Default Re: AC line Switches
Found out from Marc that the 94-95 AC components changed to metrics and therefore everything changed from prior years.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 07-14-2019   #12
Subfixer
Subfixer's Avatar
Yup, that seems to be the case.
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige
Subfixer is online now   Reply With Quote
Old 07-15-2019   #13
Subfixer
Subfixer's Avatar
I'm pretty sure the 94-95 R134a AC parts hunt is finally over.
Here's the list:
Compressor - Jerry's Gaskets
Condenser - Corvette Central
Accumulator/Dryer - Corvette Central
Accumulator Hose - Zip Corvette
Evaporator Hose - eBay
Evaporator orifice - Corvette Central
Evaporator - Old Air Products
Compressor Hose - The Parts Place
High Pressure Switch - GM Parts Giant
High Pressure Temperature Control Switch - eBay
Hard to find some of these and not all were correctly assembled (3 tries from different vendors for the compressor hose) , but the vendors in the list above had the correct parts.
Old 07-16-2019   #14
Roadster
Roadster's Avatar
How did the AC hose assembly come packed from the Parts Place?
Was there any packing material protecting the hoses and did it come in a flat long box or a more square box?
thanks for any info.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-16-2019   #15
Subfixer
Subfixer's Avatar
More of a squarish box, paper packing material, hoses folded, not kinked, metal tubes perfect. AND it was built correctly!
Old 07-16-2019   #16
Roadster
Roadster's Avatar
I was not so lucky.....same box....no packing materials at all....and imperfections in the tubing....and yes it was built correctly.....you received a good one.....mine was not so good....I sent it back.
1974 LS4 454 Vert
1974 L-82 355 Vert.
