06-02-2019 | #1 |
Coolant Vent Line Alternative
In the final stages of installing the 427. Decided to run the engine coolant vent lines under the plenum in 5/16 SS tubing. More secure than running it in hose.
IMG_0121.JPG Sent from my iPhone using ZR-1 Net Registry
06-03-2019 | #2 |
Re: Coolant Vent Line Alternative
06-03-2019 | #3 |
Do I hear a Wazoo get together in VA for the start up?
06-03-2019 | #4 |
That's some high-class work!
06-03-2019 | #5 |
I like that.. I assume you had to add ports to the IH for the coolant lines
06-03-2019 | #6 |
Yes, the same area where the coolant sensor ports are located. The casting is quite thick there. Intended for pipe thread fittings.
06-03-2019 | #7 |
Beautiful phil. You obviously understand the design intent of providing an escape path for the steam. Lotus meant for their to be a vent in this circuit. Love what you’ve done.
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
06-03-2019 | #8 |
An elegant solution Phil, dispensing with the secondaries I see... but then why would a 427 need them in the first place.
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
06-04-2019 | #9 |
Secondaries? We ain’t got no secondaries. We don’t need no stinking secondaries!
06-04-2019 | #10 |
Start up videos required.
