Old 03-31-2019   #1
Jrpontiac
Default Picked up an LT5 and ZF
I just picked up an lt5 and zf tranny. Got a really really good deal on it but it doesn't have the ECM so I may be SOL with my plan to retrofit it into a 2nd gen Camaro. Haven't done any research on if that conversion is even possible. Deal was so good I couldn't pass it up. Engine supposedly came out of a 90 zr1 with 27k miles. Car was rolled 15+ years ago and engine was pulled.
Any ideas on if ECM's are even available, who might I contact.
Worst case senario I have a cool engine for garage decor.
Jrpontiac is offline   Reply With Quote
Old 03-31-2019   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: Picked up an LT5 and ZF
You are in the right place for LT5 information. A bunch of knowledge amongst the members.
My first thoughts for an ECM would be Marc Haibeck. (ZR1specialist.com). Also, Jerry @ Jerrysgaskets.com.
Sure others will speak up with ideas.
Kenny
1990 #442
Old 03-31-2019   #3
RussMcB
I agree with Kenny about who best to contact. The MegaSquirt people have an aftermarket ECU. Do you have the harness/loom? And does the engine have all of the stuff housed under the plenum?
2nd gen Camaro, that would be cool.
Old 04-01-2019   #4
HAWAIIZR-1's Avatar
Congrats! Nice find and it sounds like a nice project when you acquired all the components.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-01-2019   #5
klork
You could do what I am doing and run megasquirt. It will be much easier to tune the the factory computer as you don't need to mess with chips. Megasquirt can tune the fuel tables its self too with auto tune.
klork is offline   Reply With Quote
Old 04-01-2019   #6
Jrpontiac
Thank you for the info. Good to know that there is an aftermarket solution.
Some questions. Engine will not be going in a ZR1.
-Are the electrical connections/ports coming out under the rear of the plenum for the ICM?
- I don't have the engine harness, if I go with the megasquirt system do I need it?
- If I used the megasquirt system do I use the ICM?
- If I need the harness are the 90-95 harnesses the same?
I'm pretty fluent in LS stuff, not some much with this C4 LT5.
Old 04-01-2019   #7
klork
You do not have to use the icm. I am going to be using LS coils as they have built in ignitors and I have used them successfully with megasquirt before. They are easy to wire up and require just 4 wires per coil. I havnt looked over all of the connectors on the engine yet but most I have seen are standard GM weatherpack connectors so it would be fairly easy to make a harness.
Old 04-01-2019   #8
Jrpontiac
Found out the flywheel and clutch is not there, kinda bummed about that. Although for $3k I still would have bought.
Old 04-01-2019   #9
I do know 8 LS coils fit under the plenum
Old 04-01-2019   #10
rbidwell
Mega-squirt has developed an ECM for the LT5 and should be available thru Jerry's Gaskets. It is the unit on my Raptor twin turbo.
If life is just a highway, then the soul is just a car. meatloaf
rbidwell is offline   Reply With Quote
