03-17-2019 | #1 |
Crankcase Vent Cover Tube Loose
To install the driver's side injector housing I was removing the vent hose from the crankcase vent cover. The hose clamp was completely loose and when I put a rotation and pull motion on the hose, the tube came out of the vent cover instead of the hose separating from the hose. (The hoses are original and very hard. New ones on order from Jerry's)
The tube wasn't damaged. There was a sealant or adhesive around the tube portion that fits in to the cover. I've totally cleaned it up plus any that was in the bore on the cover. Question: What sealant or adhesive should I use when I reseat the tube in the vent cover? Tony - Tnova |
03-17-2019 | #2 | |
Re: Crankcase Vent Cover Tube Loose
03-17-2019 | #3 |
03-17-2019 | #4 | |
Hey Tom
If you look at my album of pictures you see how I dealt with it about half way through the pictures. Hope it helps Dave https://www.facebook.com/zr1netregis...60115440860615 Quote:
03-18-2019 | #5 |
Same thing happened to me. I used Loctite 262, let set overnight. All worked like new. Phil is correct for Loctite 620 being the best for the application, I just didn't have any on hand.
03-18-2019 | #6 |
Is this the answer? I "found" these books not to long ago. Had a reason to open them up.
George Last edited by Corvettes White; 03-18-2019 at 12:50 AM. |
03-18-2019 | #7 |
To all, thanks. This is a great forum. I've got 620 on hand and will do this morning. I wish my "Brand P" racecar buddies where as knowledgeable and helpful as the LT5 crowd.
BTW, for those who have asked, yes, I do have a Nova, thus the nickname. '72, old school set up for driving to the strip for test-'n-tunes. Not as cool as my ZR-1 though. Tony - Tnova |
03-18-2019 | #8 |
George,
You have the factory assembly book? OUTSTANDING!!!! Preserve them like a library archive. Don't ever let them leave the group. Tony - TNova |
03-18-2019 | #9 |
Friend recently gave me a complete set of c-4 factory assembly manuals including one for the 1983. The 83 one may be the only one in existence according to another friend who has been looking for one for over 10 years.
Tyler
55 Polo White (Project) 61 Jewel Blue (Sold to buy above) 66 Nassau Blue 68 Torch Red 88 ZR1 Blue 90 ZR1 White |
03-18-2019 | #10 | |
Good luck with your project. |
Tags |
crankcase vent cover, hose, tube |
