02-19-2019 | #1 |
injection housing leak
After a hard drive i noticed some oil on the right side of inj housing. It looks like there is a leak from the gasket. Time to pull housing and replace the
gaskets. Should i replace the o rings on my injectors while i'am in there. Injectors are from FIC installed some time ago. I ordered new housing gaskets and plenum gaskets, but forgot to order o rings. Do i replace only the primary or do all of them. Thanks John |
02-19-2019 | #2 | |
Re: injection housing leak
FIC injectors come with new, Viton o-ring seals, except for the primary injector lower o-ring seals(8), Jerrys Gaskets PN 10067600-V. If you are not sure the o-rings you have presently are Viton, I recommend replacement. The rest of the o-ring seals are OK for re-use provided they are not damaged. Lightly lube all of the o-rings with motor oil before re-installing. Do not use silicone grease.
02-19-2019 | #3 | |
I’m curious why you recommend not using silicone grease? H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
02-19-2019 | #4 |
Silicone will damage the O2 Sensors.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 02-20-2019 at 06:08 PM. Reason: Correcting an error. |
02-20-2019 | #5 |
Actually Jerry my understanding is that silicone kills the O2 sensor, not the converter.
02-20-2019 | #6 |
You are right Dom, my mistake. I knew that but it just didn't come forward when I was recalling the issue with silicone. One of those symptoms of age.. Thanks for calling it to my attention.
02-20-2019 | #7 |
No worries. Happens to the best of us.
02-23-2019 | #8 |
Replaced mine, 5 years overdue, tighten our replace the evac cover bolts/gasket, it will be loose.
Get Jerry's core plugs and deep-6 the secondaries!!! Sent from my SM-G960U using ZR-1 Net Registry mobile app
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
