Old 03-30-2019   #1
tommy
Default Re: Timing chain guide
This I saw, but I want new
Wysłane z mojego VTR-L29 przy użyciu Tapatalka
tommy is offline   Reply With Quote
Old 03-30-2019   #2
Tommy,
I responded to your email, but the email address you gave must have an error. We do not have new PRIMARY Timing Chains in stock.
The Primary chain is very robust & I don't recall having ever heard of a failed one. I thought your problem was with the Secondary Timing Chain Guide Facing.
Old 03-30-2019   #3
tommy
It is possible that i do a mistake with my mail because i wrote it from garage
Today i checked chains and think that primary chain have big clearance, please look at below link and tell me is it normal or not
https://youtu.be/gy5_gFbuKEY
Old 03-30-2019   #4
Jagdpanzer
Jagdpanzer's Avatar
What does it look like with the primary chain tensioner set?
How worn is the contact face?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-30-2019   #5
tommy
That was with the primary chain tensioner set, tomorrow i will put photo with contact face.
Old 03-30-2019   #6
Jagdpanzer
Jagdpanzer's Avatar
I see your concern.
How many KM or miles on the chain?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-31-2019   #7
tommy
64 000 miles
Old 03-31-2019   #8
tpepmeie
I have seen instances where there is not enough adjustment on the primary tensioner to remove all the slack. It may be necessary to shim under the wear face on the primary guide. Some aluminum or steel sheet stock of the proper thickness works if all else fails.
Jerry is right, the primary chain is very stout and I’ve never known of one to fail.
If the block has been line honed, it’s likely there will be excess slack.
Old 03-31-2019   #9
tommy
That' s look my contact face
Old 03-31-2019   #10
Jagdpanzer
Jagdpanzer's Avatar
Looks normal for 64k miles
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
