Old 12-17-2018   #1
Kevszr1
Default 1992 ZR1 Registry Spreadsheet ?
I saw a post written here long ago (2009) about a data base of a 1992 ZR1 Registry but the link is no longer working. Does anyone know where I can find the spreadsheet of registered / known 1992 ZR1s or have a link?
I even found a post of the car I own but no pertinent information.
Please let me know where I can get the registry listing.
Thanks,
1992 ZR1
#497
12,500 miles
Highly Original
Original Tires
81U Bright Red / Red Interior
File Type: jpg DF40EF4E-C024-45EE-959C-AE791006447E.jpg (186.9 KB, 49 views)
Kevszr1 is offline   Reply With Quote
Old 12-17-2018   #2
Kevszr1
Default Re: 1992 ZR1 Registry Spreadsheet ?
Any help out there ?
Old 12-17-2018   #3
I am sure someone will be here soon to help. I doubt I have the spreadsheet but when I get a chance I will look
Old 12-17-2018   #4
rush91
1992 ZR-1: 1G1YZ23J7N5800497
Code
Description
UJ6 INDICATOR,LOW TIRE PRESS LOW TIRE PRESSURE IND(UJ6)
UX0 SPEAKER SYSTEM,SIX,DUAL FLOOR SILL,DUAL EXTENDED RANGE SAIL PANEL 6 SPKR SYS(UX0)
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
XAU Unk.
YBE TIRE REAR-(USED WITH ZR1) TIRE(YBE)TIRE REAR-(USED WITH ZR1) TIRE(YBE)
ZR1 PACKAGE,SPECIAL PERFORMANCE COUPE(1YY07 + ZR1 == 1YZ07) SPECIAL PERFORMANCE PKG(ZR1)PACKAGE,SPECIAL PERFORMANCE COUPE(1YY07 + ZR1 == 1YZ07) SPECIAL PERFORMANCE PKG(ZR1)
AC3 ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR(AC3)
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING"ULTIMA"INCLUDES SEAT ADJ(USED WITH TRANS AN Y84) RECL FRT BKT ST(AQ9)SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING(USED WITH BIARRITZ YP3) RECL FRT BKT ST(AQ9)SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING(USED WITH SE Z7M) RECL FRT BKT ST(AQ9)
BGR Unk.
CF7 ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7)
C68 AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS A/C AUTO ELEC CONT(C68)
DL8 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8)
D3X Unk.
E5Z Unk.
E9Z Unk.
FX3 RIDE AND HANDLING,ELECTRONIC CONTROLLED ELEK RIDE & HANDLING(FX3)
GM3 AXLE,REAR,3.45 RATIO 3.45R(GM3)
J55 BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55)
LT5 ENGINE,5.7L(5.7J),TPI 5.7J(LT5)
ML9 TRANSMISSION,MANUAL 6-SPEED 6-SPD M/TRANS(ML9)
MN6 TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)EMISSION SYSTEM,FEDERAL REQUIREMENTS(USED WITH CALIF SEVILLE YP1) FEDERAL EMIS(NA5)
NK4 STEERING WHEEL,SPORT,LEATHER SPORT WHL(NK4)STEERING WHEEL,SPORT,LEATHER WRAPPED LEATHER WRAPPED SPORT STRG WHL(NK4)STEERING WHEEL,SPORT,LEATHER WRAPPED(USED WITH INTERNATIONAL W19,SPORT APPEARANCE PKG W40) LEATHER WRAPPED SPORT STRG WHL(NK4)STEERING WHEEL,SPORT,LEATHER WRAPPED(USED WITH SE Y92) LEATHER WRAPPED SPORT STRG WHL(NK4)STEERING WHEEL,SPORT,LEATHER WRAPPED(USED WITH SL Z7R,CONV Z7S,SUPREME Z7P) LEATHER WRAPPED SPORT STRG WHL(NK4)STEERING WHEEL,SPORT,LEATHER WRAPPED(USED WITH STE Y88) LEATHER WRAPPED SPORT STRG WHL(NK4)STEERING WHEEL,SPORT,LEATHER WRAPPED(USED WITH WJ7) LEATHER WRAPPED SPORT STRG WHL(NK4)
QA2 WHEEL,17X9.5 FRONT,17X11 REAR,STYLED(ALUMINUM) SPECIAL PERFORMANCE WHL(QA2)WHEEL,17X9.5 FRONT,17X11 REAR,STYLED(ALUMINUM)(USED WITH SPECIAL PERFORMANCE PACKAGE ZR1) SPECIAL PERFORMANCE WHL(QA2)
U1F RADIO,AM/FM STEREO,CASSETTE,C.D. PLAYER,ETR,BOSE,INCLUDES CLOCK CASSETTE/CD PLAYER(U1F)
73I INTERIOR TRIM,FLAME RED (73I)
733 TRIM COMBINATION- LEATHER,FLAME RED (733)
739 SEAT BELT COLOR,FLAME RED (739)
81U EXTERIOR COLOR,PRIMARY (81U)EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
1AZ Unk.
1SA PACKAGE-OPTION 01 (1SA)
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)ANTENNA,POWER(CHROME) PWR ANT(U75)
IL3 TRIM,INTERIOR DESIGN (IL3)
D8I SENSOR-VEH SPD (10456089) (D8I)
FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1)SUSPENSION SYSTEM,SOFT RIDE(USED WITH RS PACKAGE Y86) SOFT RIDE SUSP(FE1)
R9Z Unk.
KW2 GENERATOR,124 AMP 124 AMP(KW2)
Old 12-17-2018   #5
32valvZ
32valvZ's Avatar
I started to compile information years ago about 92 ZR-1's specifically..... Allot is hand written... I will dig it out and see what I have. IIRC, it was basically color combinations of every 92 I could find, weather they were salvaged and other info.... Ill need to scan and post it.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 12-17-2018   #6
spork2367
I assume you're talking about a list of owners, not options. That spreadsheet was taken down by someone who got their feelings hurt, or felt like it should be private information. It used to be public. I don't know if it still gets updated or not.
Old 12-17-2018   #7
Kevszr1
Yes, I’m trying to find out which 1992 ZR1s are registered and still “alive” being I have a late serial #.
Old 12-17-2018   #8
Kevszr1
Thank you very much for the information! Any list you can dig up will be appreciated.
Old 12-18-2018   #9
I've got #043, Aqua/Gray ;-)
Old 12-18-2018   #10
dredgeguy
dredgeguy's Avatar
I have #246 Red/Black
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Tags
1992 serial numbers list, 1992 spreadsheet, resisted list
