Old 06-11-2018   #1
Ccmano
Default WTS Misc Engine / Trans related parts
Everything is sold thanks for looking[Items added - New Pix] Everything is used. Shipping is extra...
Bolts and bolt sets, used OEM in good condition
Complete set of OEM cam cover bolts 48/6 none striped. $50
2 Complete sets of Stock Plenum Bolts $15 per set.
Bell housing to block 7 bolts $40
Trans to bell housing 5 bolts $35
Belt tensioner 1 bolt $15
Throttle body to plenum 5 bolts $40
Injector housing to head 20 bolts $50
AC compressor to block 3 bolts $20
AC pressure hose 1 bolt $10
Pressure plate to fly wheel 6 bolts $25
Bellhousing check cover 3 bolts $20
Fuel rail to IH 4 bolts $10
Starter to block 2 bolts $25
Electrical ground to block 2 bolts $10
Buy all the bolts listed here $150 firm.
Secondary Vacuum Solinoid, 91’ $75
Air injection pump, 90’, $90
Cam Position Sensor, 90-95, $85
Transmission bell housing with fork and pivot that show very little wear, 90’, $199
Pressure Plate, looks to be a late production LT5 spec. replacement, 91’ $150
OEM GM Clutch Disc (~50% wear) $50
Knock Sensor 91’ $20
ZF6 Shifter & Linkage Complete Stock, Band New $115
PCV Hoses & Valves $85
Memcal Performace Chip 90’ Z-Industries not sure what they adjusted, typically timing, fans on earlier, skip ship elimination. $175
9 OEM Delphi injectors, 35k Miles/ 91’, 5 Secondary 4 primary, all ohm ~12.5, good if you need OEM, $50
Oil cooler, very clean, 35k Miles, 91’, $209
4 original 91’ coils 35k Miles, $25 each $80 all
91’ Coil base and tray (damaged) but functional. $175
Spark plug wire set, red AC/Delco replacements. Out of the 91’ $50
Oil filter housing adapter assembly 90’. $199
Old 06-11-2018   #2
Ccmano
Default Re: WTS Misc Engine related parts
Old 06-11-2018   #3
Ccmano
Old 06-12-2018   #4
tnova
Interested in the engine mount insulators. PM sent.
Tony - Tnova
tnova is offline   Reply With Quote
Old 06-12-2018   #5
Ccmano
Tony - Tnova
Replied... more items added.
H
Old 06-30-2018   #6
Ccmano
Fourth of July bump...
H
Old 07-13-2018   #7
Ccmano
Updated...
Old 07-14-2018   #8
zr1assassin
Are you parting out the entire car?
zr1assassin is offline   Reply With Quote
Old 07-14-2018   #9
Ccmano
No, just the engine and trans. What you see here is basically what I have left. I bought a complete engine/trans out of a low mile car earlier this year. This is how she looks now...
H
Old 07-14-2018   #10
zr1assassin
Wow looks fantastic!
