Old 05-17-2018   #11
BigIke
Default Re: Alternator
Buy Jerry's.... You'll waste time/money everywhere else. If you send your original in, keep the original pulley. Jerry's comes with a smaller pulley, if you spend a lot of time near the rev-limiter it could lead to Alternator SIDS.
I pull the upper plenum and the alt can be done in 45-mins. Good time to wire the secondaries open as well
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
BigIke is offline   Reply With Quote
Old 05-17-2018   #12
lfalzarano
Easier just to pull the air horn.
Lou
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 05-18-2018   #13
KPW
KPW's Avatar
Lou
I'm with you on this one. I've got a step-by-step with needed tools here:
http://www.zr1.net/forum/showthread.php?p=248848
Sent from my iPad using ZR-1 Net Registry
1991 ZR-1 #1438 Black/Black & Red
KPW is offline   Reply With Quote
Old 05-18-2018   #14
Young1
Young1's Avatar
I have twice now replaced alternator. I removed throttle body. Did not have to remove oil sender or tensioner. First time I had unit "rebuilt" last November. Replaced it with one of Jerry's on MR6 two days ago. Thank you Jim Voter! However I believe the easiest would be to lift plenum. As long as you have gaskets.
Old 05-18-2018   #15
KPW
KPW's Avatar
Ah, yes. Throttle body remove would make it so you wouldn't have to remove the oil sender. Probably makes it easier to access behind the alternator for (+) terminal too. Many ways to skin this one
Old 05-18-2018   #16
Young1
Young1's Avatar
We did it in 2 hours in parking lot with just the minimum of correct tools.
