04-01-2018 | #31 |
Re: Optima or Odyssey ... close dimensions, will it fit? ---
Stinger short bolt must be shimmed by using brass colored plate, flat washer, lock washer ...or cut thread length and run threads before installing to terminal threads. I prefered the addition contact area by using the plate.
Install is '96 CE, no battery disconnect retains the key fob proximity door unlock&lock feature.20180331_123946.jpg Sent from my SM-N920V using Tapatalk
1990 ZR-1 #1587 1990 ZR-1 #1727 |
