08-26-2017 | #1 |
Thought only ZR-1's had the high stop light?
08-26-2017 | #2 |
Re: Thought only ZR-1's had the high stop light?
All coupes had them until the style refresh in 1991. From that point on, only ZR-1s had them and the base coupe had the third brake light integrated into the rear fascia.
Scott
WAZOO Member '95 Callaway SNAT 450 Aerobody Coupe - Black/Black '92 Callaway SNAT 400 Convertible - Polo Green/Beige '91 ZR-1 #1231 - Arctic White/Saddle (SOLD) '90 ZR-1 #2547 - Turquoise Metallic/Black '89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black '85 Corvette 454 Coupe - White/Red |
08-26-2017 | #3 |
That's disappointing, since I thought I could determine a Z from the side. Now I have to check out the rear license plate spacers and rounded butt! [emoji16] Thanks for the info.
08-27-2017 | #4 | |
Rocker panels are different on the zr-1.
[B][U]1991 No. 519[/U][/B] |
08-27-2017 | #5 |
86-90 all Coupes. When the 86 first came out I HATED that damn tacky add on light. When the Z came out,they just had to throw it on there.
08-27-2017 | #6 |
Is it possible to see the difference on the rocker panel (1990)?
08-27-2017 | #7 |
08-27-2017 | #8 |
It's actually rather simple to identify a Z. They are the only ones with the high stop light and the bubble butt combination. If it doesn't have both it's not a Z.
H
90'ZR-1 #1461 Red/Black Ported Intake, Degreed Cams, OBX Headers & Exhaust, Fidanza FW, Secondary Delete, Custom tune, C6 GS Wheels. Sold 08 C6 Z51 Crystal Red Metallic Sold Vararam Intake, Tune, Sold 05 C6 Z51 Red/Black Sold 90'ZR-1 #1723 Black/Gray Sold but not forgotten 91' Z51 L98 White Vert. My First, you always remember your first. Sold. |
08-27-2017 | #9 |
If seen from the front, the Z also has a much more pronounced shoulder where the non-Zs have a smooth transition from B-pillar to rocker panel.
- '90 ZR-1 |
08-27-2017 | #10 |
From the front there is a subtle flair starting at front of door.
From the rear the license plate spacers are the obvious giveaway. From the side, the rear wheels have a deeper recess than the front. And of course, the CHMSL. All this is easily spotted at a glance by most ZR-1 owners, even across six lanes of interstate, going the other way at 80mph ) Sent from my iPhone using ZR-1 Net Registry
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
