05-07-2017 | #11 | |
Re: Any risk in swapping radiator caps?
Reducing the system pressure is a patch on a likely small problem that can result in premature boil-over in an engine that is somewhat prone to overheating in certain conditions. With summer coming on, it's the best time to make sure the cooling system is in top condition.
