Old 01-20-2017   #1
henryr
Default dealer service - injectors question
if i dropped my car of at the local chevy dealer and they wound up replacing the injectors.... and the used gm parts
the factory parts are still the same shitty steel internal injectors that would become a problem with ethanol gas again or ?
henryr is offline   Reply With Quote
Old 01-20-2017   #2
Default Re: dealer service - injectors question
most likely yes.
Old 01-20-2017   #3
The 90 injectors are the ones prone to issues.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-20-2017   #4
Where's WVZR-1 when we need 'im? I have ot in my mind the suseptability to alcohol extended thru the 92 MY. No?
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 01-20-2017   #5
No change in injectors until 93MY. Changed then for alcohol fuel resistance
Old 01-20-2017   #6
not so sure about that. we did have to swap lance millers injectors on his yellow car
Old 01-20-2017   #7
It's documented by Graham in paper regarding 93 MY changes
Old 01-20-2017   #8
Vette73
I really hope your not thinking of letting a dealer service your car..
Yes, if you did they would probably replace them with the same lousy injectors..I would never bring a ZR-1 to a dealer for service...
Old 01-20-2017   #9
Demps
Demps's Avatar
Bring it to FL. I'll put them in.
Ted
Demps is online now   Reply With Quote
Old 01-20-2017   #10
I've taken my z to a local dealer and it's been fine. I bring my own parts, they install them, no real issues.
