Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 03-04-2017   #1
S.hafsmo
S.hafsmo's Avatar
Default Re: 90 ZR-1 #2273 - To be rescued
Truly appreciate that, Jeff.
I was kinda hoping to find it at Jerry's or something, so I could just pop it in with a bigger order, but so far no such luck.
- '90 ZR-1
Old 03-09-2017   #2
S.hafsmo
S.hafsmo's Avatar
A bit of Filipino motorman art. Not really Z-related, but too nice a piece not to share.
- '90 ZR-1
Old 03-10-2017   #3
S.hafsmo
S.hafsmo's Avatar
Thanks! I've replied to your e-mail.
Ordered 20 pcs of ebay.
Also added a couple words on the Corvette America leather seat covers in an earlier post, in case anyone were to consider these.
- '90 ZR-1
Old 04-22-2017   #4
S.hafsmo
S.hafsmo's Avatar
New wheels received from Steve Jasik!
I'm thinking it'll look more appropriate than the BMW winter rims.
- '90 ZR-1
Old 04-22-2017   #5
I had heard that BMW wheels would fit.
Old 05-08-2017   #6
S.hafsmo
S.hafsmo's Avatar
BMW wheels fit rather well. You just need hubcentric rings and "wobble nuts". Not something I'd take to the track though.
Next issue was a leaky check-valve on the secondaries, so the plenum was pulled. Wouldn't say it's any harder to do than any other plenum removal job (on euro cars, that is).
It didn't look that bad below, but definitely in need of some cleaning. The crankcase hoses were hard as rocks, but remaining hoses were not bad at all.
Removed the starter for overhaul, and to clean the drain.
I assume these are the Accel 150821 injectors? They are marked 01D109B and 21 lb/hr.
- '90 ZR-1
Old 05-08-2017   #7
S.hafsmo
S.hafsmo's Avatar
Here's the starter overhaul kit, ordered at advice from WVZR-1.
Part number ND-17-1103
It does contain pretty much all you'll need to service the starter, but does not contain the bearings on the crank gear.
Didn't look all that bad inside,
Note, there was nothing wrong with the starter before the service. Just preventive maintenance. Started right up when it all was assembled again.
- '90 ZR-1
Old 05-08-2017   #8
S.hafsmo
S.hafsmo's Avatar
Did some TB cleaning as well, where I found no DAG on the sealing surfaces, which might be the cause of my idle issues.
And this is just to illustrate the sad/cramped surroundings of my miniature garage. And of course because Z's are rather nice to look at and it deserves a picture.
- '90 ZR-1
Old 05-20-2017   #9
Nothing like "hands-on" to learn a new (different) vehicle! (Mine isn't named after the Phoenix bird for nothing!) Looks like your ol gal is in good, caring hands now.
Old 05-20-2017   #10
S.hafsmo
S.hafsmo's Avatar
Thanks Paul. I saw that news clip from the C4 gathering, pretty neat!
The car's currently wrapped up with all new vacuum hoses/actuators/check-valves, as well as nice, new red spark plug wires (it came with gray ones). Thanks to Jerry's Gaskets and White Racing for supplying the parts.
I even got the mandatory carter bling.
The car is now finally approved, and I'm just waiting for my new shiny plates to arrive. About time, as it hasn't been on the road (approved) since 2013.
That doesn't mean the car's finished though. As with all other US car's I've had, the door hinges sag a bit, so I took them of to replace hinge pin/bushings.
Took one hinge at the time, with the door closed to avoid it moving. I did however re-adjust the door afterwards, as it wasn't aligned properly. Since the OEM hinge pins are pressed flat after assembly, the new ones were just installed with these toothed retainer washers you can glimpse here.
The lower hinge still had some axial play after replacing pin/bushes (approx. 1mm), so I'm considering to replace the whole hinge if I can find a new one somewhere. Truth be told, I'm not really satisfied with how tight the new hinge/bushes were at all. These came from Corvette Central. But as I do not have any other to compare with, I can't tell whether they're within spec.
- '90 ZR-1
