Old 10-16-2016   #1
BlackZR1
BlackZR1's Avatar
Default Aarrgh! crack in my windshield!
Looking around the car with a flashlight and I notice this crack at the bottom driver's side corner of my original windshield. Almost invisible without the flashlight at the right angle.
I guess the good news is that it begins and ends at an edge so it won't travel but what would cause a crack at this location?
Thanks,
Roger
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 10-16-2016   #2
Default Re: Aarrgh! crack in my windshield!
Was the car jacked up recently? Possibly with the roof off?
Old 10-16-2016   #3
BlackZR1
BlackZR1's Avatar
Yes, I've had it jacked up a dozen times over the last year. Plastic roof is always on. I'm usually careful to use 2 jacks at the front jack points (1 on each side) lifting a little at a time alternating each side until I can get my larger jack under the front cross member. I've heard the forum mention how jacking unequally can cause cracked windshields so I have been careful.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 10-17-2016   #4
BigJohn
BigJohn's Avatar
Been doing wheel stander starts?
Old 10-17-2016   #5
BlackZR1
BlackZR1's Avatar
Haha, I wish that was the cause!
I need a few more ponies for that.
What makes me mad is that I have taken great care not to lift either side unevenly for exactly this reason.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 10-17-2016   #6
BigJohn
BigJohn's Avatar
Yeah a cracked windshield really sucks.
I have both tops; I leave my hardtop in all the time.
Old 10-17-2016   #7
Ryan Chappel
Ryan Chappel's Avatar
I have never taken the top off....PO never took the top off....
When I first posted here, I mentioned that I understood there was a lot of flex and a potential windshield damage issue when jacking unevenly...
....I remember a difference of opinion among posters here..
Ryan Chappel is offline   Reply With Quote
Old 10-20-2016   #8
Blownrunner
I thought that using the under the rocker stiffening bars help this? Installed them on mine and adjusted. Addressing the flexing body is a far better mod than any other for this car. On a brighter side, will insurance cover it? I have the classic car insurance and the windshield repair is 100% reimbursable. Then you can get one of those fancy hi-tech reproduction windshields for free.
Blownrunner is offline   Reply With Quote
Old 10-21-2016   #9
BlackZR1
BlackZR1's Avatar
You are probably correct about insurance coverage. The picture I posted was while shining a flashlight at just the right angle to make the crack visible. In normal lighting it is invisible unless you are looking for it very closely. It is also down in the corner in the dark tint framed area so I'm not going to worry about it. The glass is perfect in every other way, no other chips and no delamination. Plus I risk damaging the trim that others have cautioned about. It just really pi$$es me off that it occurred while I've been so careful about jacking the car up and down evenly.
I would think some of the uneven roads and driveways or changing a tire with the factory jack lifting a single front tire off the ground would have flexed the chassis more than anything I would have done.
I should probably put the hardtop on instead of the plastic one for some extra rigidity.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 10-21-2016   #10
tccrab
tccrab's Avatar
I've driven "Girlfriend" with targa top out, jacked her up with the top out, and jacked her up with the top on.
I did leave the top on when I put her up on very tall jackstands when I replaced the transmission.
That being said, no cracks.
Heck, I don't have any delam either.
Go figure.
Having driven girlfriend with her top off, I can tell you that you don't want to go much past 125 or so.
I'll mess up your comb-over.
It gets really noisy and the buffeting is pretty severe. Rolling up the side windows helps, but doesn't cure it.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
