06-19-2016 | #1 |
Fuel pump hotwire
How do I run the pump(s) by jumping the red spade connector???
06-19-2016 | #2 |
Re: Fuel pump hotwire
With the ignition switch OFF, jumper the battery POS directly to the spade of the connector*
Both pumps should run and continue to run as long as the power is applied and the ignition switch remains OFF. BTW, configuring the VOM to read amperes, you can measure the current draw. The current draw is the total for both pumps; approx 8-10 amperes total.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry |
06-19-2016 | #3 |
Thanks!!! ....Did you ground to the frame of just NEG side of batt???
The whole purpose of this is to clear the lines and check the current... |
06-19-2016 | #4 | |
Connect the VOM (configured to measure amperage) between the positive battery terminal and the fuel pump test (spade) to read current.
06-19-2016 | #5 |
I'm using a VOM don't worry!!!.. Thank-you!!!
06-20-2016 | #6 | |
To quote Alfred E. Newman: "WHAT? ME WORRY????"
Oh, I'm not worried, cuz you ain't usin' my VOM! But, when you said... Quote:
Note: No offense to you if you're fully aware; but in case you are not, let me say it is a good idea to move the probe from the "A" port on the VOM back to the VOLT - OHM port as soon as you're done measuring current to minimize the chances of forgetting and attempting a voltage measurement. (Ask me how I know!) And, I recommend switching the VOM to "A" before connecting the test leads in series with the load to avoid arching the contacts in the VOM.
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 06-20-2016 at 08:45 AM. |
06-27-2016 | #7 |
I got a 6.17a reading...
06-27-2016 | #8 |
Assuming proper connection/setup, THAT reading appears to be low, i.e., one pump only, or one pump may be faulty, or a bad connection(?).
While monitoring the current, pull the FP1 fuse on the main panel and see what the current is. (Current adds in this case. So, pulling only one fuse and seeing what current remains will tell us what the current draw of each pump is.) Here is a schematic from a 90 FSM which I hope is similar enough to work on later mo cars too. (Someone may correct me if this isn't accurate beyond the 90 Zs) Fuse location (1990): one on the main fuse panel, one on the auxiliary panel accessed behind/under the passenger knee panel).
[I][COLOR="Blue"]Good carz, good food, good friendz = the best of timez![/COLOR][/I] 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 06-27-2016 at 12:26 PM. |
06-28-2016 | #9 |
I got 0.46A with FP1 pulled.
06-28-2016 | #10 |
Well, that's a problem. It should be in the 4-5A range w/ FP1 pulled (ignition switch in OFF position). So, "ringing out" the circuit and ultimately the fuel pump to find the problem is next. It could be a bad relay or even a connector (ask Jim Voter about his experience w/ pump connectors!).
Present company excepted; BUT! For all that say chit like "It can't be "this or that (part)", because I replace it", especially when dealing with foreign-made parts, one has to VERIFY the replacement part is working. NEVER ASSUME! Just b/c it is "new", doesn't mean it works, OR that it won't fail shortly after it is installed. (Statisticians call it "infant mortality"; the period when a device is most likely to fail is when it is first installed!) Example: One of my new pumps failed right out of the box! Just sayin..... Anywayz... sounds like you're on the right path.
