01-31-2016 | #31 |
Re: F/S 1995 Corvette ZR1 Torch Red/Tan #186
You're having too much fun Cliff! You're building up quite a collection of Zs there! You'll see more as you did further into it. I really love mine and it's a keeper. I wish I could keep the 90 too as it was my intent to have first and last year.
01-31-2016 | #32 | |
If that makes sense Just a Heads Up....Jerry has New Secondary Port Throttle Vacuum System (Complete) for the 93'-95', New Map Vacuum Hose, and New Fuel Regulator Vacuum Hose in his inventory. I highly recommend these hoses along with the New PCV System four Hose/Connectors which totally eliminates the need for Nylon Ties, and Screw Type Hose Clamps. Oh Ya......These NEW Hoses/Connectors also TOTALLY Eliminate all Vacuum System Leakage. Secondary Port Throttle Vacuum System
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-31-2016 at 12:14 PM. |
01-31-2016 | #33 | |
Actually… congrats! A beauty! Have you ever posted a pic of your workspace/garage, Dynomite? As organized and detailed as your posts are, it must be both equipped and immaculately laid out.
'94 ZR1 LT5 - Dark Red Metallic '79 L82 4-speeds of fun '96 LT1 Borla, H-pipe, TB, CAI (Sold) "An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered." -- G.K. Chesterton |
02-01-2016 | #34 | |
Looks like a sweet find!
[LEFT][SIGPIC][/SIGPIC][/LEFT] [CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER] |
02-01-2016 | #35 | |
If I have Parts in hand, it takes one day to Remove Everything under the Plenum and Degrease/Pressure Wash. One Day to Think. and The Third Day to put it all back together with New Parts where Required (Including Blocking TB Coolant). Some Modifications are Included
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-01-2016 at 09:31 PM. |
03-08-2016 | #36 |
Summary of 1995 LT5 Top End Restoration #186
All 95' cars have the Dunn heads on the left side: #10225121 This 95' has the Dunn head on the right side also: #10225122 Summary of 1995 LT5 Top End Restoration with some additional ZR-1 Restoration (Drive Train and Chassis) 1. Rebuilt Starter 2. New 200 amp Alternator (Just Because) 3. New Secondary Vacuum System and Linkage (Complete) from Jerry (Canisters Reconditioned) 4. All Injectors Ohmed (12.4 Ohms) and Cleaned with New "O" Rings 5. New Plugs and New LT5 Plug Wires (Raised to Plenum) 6. TB Coolant Blocked at Injector Housing (Re-installed TB Coolant Hoses for looks only) 7. Billet Aluminum (Oil Cap, Belt Tensioner Pulley, Power Steering Pulley, Water Pump Pulley) 8. Lees MAP Sensor Cover with 1995 #186 9. New Crankcase Vent Cover Gasket with red Loctite on all bolts and two New Vent Cover Hoses from Jerry 10. Four New PCV Hoses from Jerry not requiring any clamps of any kind 11. New Charcoal Canister 12. Engine completely Degreased and Cleaned (Pressure Washed) with Compression at 215-220 on ALL eight Cylinders 13. Differential Drain Plug Installed 14. All New Fluids (Differential, Trans, Engine) and New Oil Filter 15. New TB Coolant Hoses albeit there is NO TB Coolant 16. New "O" Rings (Injectors, Fuel Rail, Cam Cover PCV) 17. New MAP Hose and New Fuel Pressure Regulator Hose 18. SS Allen Head Bolts (Plenum, MAP, Air Horn, Injector Housing Coolant Manifolds) 19. New Tires (Came with ZR-1) 20. And.....New Garmin Mapping (In case I get Lost being distracted while driving the "New" ZR-1) 21. And almost forgot.....Wireless XM Radio....Just Tune Bose to same frequency (using IPhone APP to find frequency) 22. Complete set of Metric tools behind Passenger Seat 23. Gorilla Lug Nut Wrench and Dynomite Tow Bar beside Passenger Seat 24. K40 Radar installed (Came with ZR-1) 25. LoJack Installed (Came with ZR-1) 26. Carter Bling (Billet Aluminum Covers for Oil Filter, Brake Fluid, Coolant Over Flow, Power Steering, Wiper Fluid, Throttle Cable) 27. New Radiator Hoses 28. Radiator (oil cooler and Air Condenser) was Clean of Trash (may install Radiator Screen) 29. Under Side of Engine and Differential was degreased and pressure washed (No Oil Leaks) 30. C4 Beam Plates Installed (ZF doc) 31. New Hood Support 32. Recharged the R134a AC System 33. Greased zerks on Front A-Arms (Top and Bottom) and Inspected/Restored Brake Calipers/Pads 34. Reinstalled Canadian daytime running lamps Module mounted on ASR Box 35. Radiator Debree Screen installed 36. Inspect Chain Guide Wear 37. Braided SS Oil Cooler Lines Carter Bling 1995 LT5 SPECIFIC TOP END REBUILD TRICKS A 1995 Top End was rebuilt and best tricks linked here Post 230 - 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Post 231 - Clean Up of Valley and Removal Of Crankcase Cover (gasket replaced) Post 232 - Installation of Rebuilt Starter, New Alternator, and Braided SS Oil Cooler Lines Post 233 - Battery Disconnect Switch and Installation of Coils Post 234 - Installation of New Secondary Port Vacuum System hoses Post 235 - Installation of Reconditioned Injectors with New "O" Rings Post 236 - Installation/Relocation of Plug Wires and New Spark Plugs Post 237 - Blocking TB Coolant Post 238 - Reconditioning and Installation of Plenum with SS Allen Head Bolts Post 239 - Addition of Billet Aluminum Power Steering, Water Pump, Belt Tensioner Pulleys Post 240 - Reconditioned 1995 Engine with New Fluids all around including Differential Drain Installed
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-16-2016 at 12:32 AM. |
03-15-2016 | #37 |
Carter's BLING on 1995 #186
Master Brake Cylinder Cover.........................................Coolant Overflow Cover Power Steering Fluid Cover............................................Coolant Reservoir Cover and Fuel Line Bracket Windshield Wiper Washer Fluid Cover................................Throttle Cable Brackets |
03-16-2016 | #38 |
Nice car Cliff. You have the market cornered on red with saddle interior z's. Looks like a well maintained car. Enjoy my friend.
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
