03-14-2016 | #21 | ||
Re: Engine limited to 5000 rpm 1990 ZR1 LT5
I have found that New Vaccum System lines and connectors will actually hold vacuum after you turn the key off and come back and check an hour later. It is amazing that the original hardened rubber Vacuum Connectors will never completely hold vacuum. Jerry.....if you ever decide to build/obtain the NEW Secondary Port Throttle Vacuum System for the 90'-92'......let me know
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-14-2016 at 01:39 AM. |
