12-21-2015 | #11 |
Re: Brake pedal too low
If you haven't already installed them, consider installing speed bleeders before you do bleed the system. Not terribly expensive and makes bleeding the brakes a reasonably quick & easy, one person job. I know there are other recommended methods but speed bleeders have been very helpful to me. I no longer dread the job and consequently do it much more frequently than I used to ... definitely before/after track events/hard driving. And fwiw, I'm using a really good bang-for-the-buck as well as readily available brake fluid (dare I say it?) ... Ford HD.
12-22-2015 | #12 | |
Thanks! |
12-23-2015 | #13 | |
I like the motul stuff too.
95 390 LPE ZR1 (505 rwhp) LSV = Lingenfelter Super Vette Twin Turbo 2003 Z06 (800 RWHP) |
12-24-2015 | #14 |
Yun,
I had the same problem on my 67 two weeks ago, replaced power brake booster and that solved the problem. Nelson
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
12-24-2015 | #15 |
Upon close inspection, I noticed fitting on the plenum for the brake vacuum booster was loose. Once tightened pedal height seems ok. Nonetheless, I'm going to flush the brake fluid - been 3-4 years since the last flush.
12-24-2015 | #16 | |
Speed bleeders are either "love 'm or hate 'm" and they're not all created equal it seems. The 639540 I guess is spec'd for your calipers? Wilwood? Last edited by WVZR-1; 12-24-2015 at 05:33 PM. |
12-25-2015 | #17 | |
12-25-2015 | #18 |
Yun,
Who did you buy them from, I need to order some? Nelson
12-25-2015 | #19 |
12-25-2015 | #20 |
If it's for 84 through 04 Corvette you need Russell 639630.
http://www.ebay.com/sch/i.html?_odkw...39630&_sacat=0 |
