#1 | |
![]() Join Date: Mar 2006
I'm still planning on coming down to visit one day. I've been down to my sisters place a few times over the past several months, usually just helped with their place and headed home. ![]() |
![]() Join Date: Nov 2013
speaking of leaks... anybody ever have a leak from a head plug?? there are plugs on the underside of the heads near the firewall and I see seepage out of one of he plugs on the right head closest to the firewall. it is not a heavy leak but enought to have my cleaning 2 drops a month from my garage floor.
ed ramos #3028 |
#4 | |
![]() Maybe thicker "O" ring is required. I would say nothing wrong with using two "O" rings. On the Cam Sensor....Groove diameter closest to the collar is .710 diameter and .10 width. Groove closest to end is .710 diameter and .095 width but that measurement may be the same as width of first. The OD each side (and between) the "O" rings is .807 and the ID of the bore in the Head is .810. The Diameter of the main body of the Cam Sensor is .740.
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-24-2015 at 06:08 PM. |
